Hi everyone, I’m working on a low-power camera application using the EOS S3, and I’m trying to optimize power consumption during intermittent image capture (e.g., capturing 1 frame every few seconds). Currently, I see higher-than-expected power draw even when the system is mostly idle between captures.
Has anyone here successfully minimized power usage in a similar use case? Specifically:
Which sleep mode works best between captures?
Are there recommended ways to fully gate the camera interface or MIPI block when not in use?
Any tips for reducing wake-up latency without increasing overall power consumption?
Appreciate any insights or examples from real projects!
EOS S3 Camera Power Optimization
What sleep mode are you currently using between captures?
gordonpiper
I ran into the same issue on EOS S3, and the key insight for me was that “idle” isn’t really low power unless you explicitly shut things down.
This is a great question! Optimizing power for intermittent capture on the EOS S3 can be tricky. For sleep modes, have you looked into deep sleep with an RTC wake-up?
Snow Rider 3D
Snow Rider 3D
EmmaParsons
I faced something similar on a battery-powered wildlife camera. The biggest improvement came from using the deepest sleep mode that preserved only the RTC and wake-up source, then powering down the MIPI and sensor rails between captures. I also measured each state transition rather than relying on datasheet estimates, since regulators and pull-ups added noticeable leakage. Before optimizing, I used the Cps Test platform to check timing consistency across repeated cycles; it helped separate firmware delays from hardware wake-up time. A short wake-up benchmark is definitely worth doing.
chilechevrolet
This is an excellent question! Optimizing power for intermittent capture on the EOS S3 can be challenging. Have you considered deep sleep with RTC wake-up?
Snow Rider
Snow Rider
