Should bug reports regarding the 'official' EOS-S3 toolchain be submitted here in the forums, or at the QuickLogic github repo[1] ?
Asking because the above repo hasn't been updated in about 2 years...
Some of the EOS-S3 constraint issues I've encountered have been fixed in the newer F4PGA toolchain[2], but its EOS-S3 flow is labeled as "currently unsupported" [3].
-Brian
[1] https://github.com/QuickLogic-Corp/quic ... -toolchain
[2] https://github.com/chipsalliance/f4pga
[3] https://f4pga.readthedocs.io/en/latest/f4pga/Usage.html
"Quicklogic EOS-S3 (currently unsupported, provided only for development purposes)"
Bug reporting for EOS-S3 FPGA toolchain
The QuickLogic support for EOS S3 has been rolled into the f4PGA release at https://github.com/chipsalliance/f4pga-examples
Instructions on installing and running the demo is available at https://f4pga-examples.readthedocs.io/e ... tting.html
Example project is available at https://github.com/search?q=qorc-onion- ... positories
You are correct f4PGA are not supporting EOS S3, so please log any issues here and QuickLogic will look to see how we can support.
--Robert
--Robert
Are you prepared to engage with the most amusing brawler available online? Ragdoll hit is accessible without cost, unimpeded, and can be found right here. Press the play button above and determine if you possess the skills to endure the ragdoll mayhem!
