Implementing period sleep and wake up in qf_ssi_ai_app Project
Sofiaarker
I recall a similar debugging moment where a flutter app hung due to an misrouted timer callback, and a clear state diagram clarified the issue. In this Connections Game of keeping subsystems aligned, precise sleep intervals matter for reliability and power efficiency.
kaidy
A low-power wake/sleep cycle would be a great addition to the qf_ssi_ai_app project. Waking the QuickFeather every 10 minutes to perform audio recognition and then returning to sleep could significantly reduce power consumption for battery-powered applications. I'm also interested in learning the recommended approach for configuring the timer, handling wake-up interrupts, and reinitializing the audio pipeline after sleep. Any sample code or documentation would be greatly appreciated. Thanks! fnaf 1
kaidy
You may want to check whether the qf_ssi_ai_app already has a power management example. Sometimes the wake-up timer and audio pipeline are already supported but just need to be configured.
