Hi, when debugging why a USB-C to USB-C cable wouldn't even get power on a MacBook Pro port, I stumbled across the schematics for the QuickLogic thing+
Unfortunately the USB-C implementation is 100% out of spec -- it doesn't connect the CC1/CC2 pins to anything (!) when it needs to connect them to ground via a 5.1k termination resistor.
https://github.com/sparkfun/QuickLogic_ ... ematic.pdf Take a look at the USB-C connector: the CC pins are simply left floating. Without them the host won't even know there's anything on the line and doesn't allow any power.
A USB-A to USB-C cable is required because the QuickLogic thing+ USB Type C connector is not implemented correctly
Wow, that sounds frustrating! Have you ever encountered something similar where a device completely disregarded a standard? I once had a USB drive that claimed to be 3.0 but consistently performed at 2.0 speeds, no matter what I tried. It was definitely a lesson in trusting, but verifying. Makes you wonder what other corners are being cut, like when Freddy Fazbear is "just" malfunctioning.
This design has a serious problem with the USB-C standard. Leaving the CC1/CC2 pins completely unconnected means there's no "handshake" mechanism between the device and the host, which is essential for determining the power/device role and the permissible current level. Without the standard 5.1kΩ pull-down resistor, the MacBook won't recognize the device's presence and therefore won't activate power delivery via the USB-C port. fun games
In other words, while the cable or circuit may be "plugged in," it's virtually invisible to the host electronically. This design flaw completely contradicts the USB-C specification and clearly explains why there's no power or response upon connection.
Hi, good question — happy to summarize how this works and where its limits are.
The implementation is intentionally minimal. USB 1.1 full-speed signaling is 3.3 V, which standard LVCMOS33 FPGA I/O can drive directly, so the hardware is just: D+ and D− wired to two FPGA pins (usually through ~33 Ω series resistors), plus a 1.5 kΩ pull-up on D+ to identify as a full-speed device (on D− for low-speed). Everything else is done in gateware: the design runs at 48 MHz to 4x-oversample the 12 Mbit/s stream, recovers the clock from data edges, handles NRZI decoding, bit-(de)stuffing, CRC5/CRC16, and implements the serial interface engine and enumeration logic .
On the limitations: I want to be upfront that since there is no USB PHY in this design, it was never implemented as — and was never intended to be — fully compliant with the USB specification. A real transceiver provides a true differential receiver, controlled 90 Ω differential output impedance, spec-compliant edge rates, 5 V tolerance, and ESD protection. Bare FPGA pins only approximate these: the series resistors roughly match impedance, the inputs are sampled single-ended, and the I/O has no 5 V tolerance, so a VBUS short to a data line can damage the bank. You also need a crystal-derived clock (full speed allows only ±0.25% frequency error), and 12 Mbit/s is a hard ceiling — high speed (480 Mbit/s) requires an external PHY (e.g. over ULPI). In practice it enumerates and runs reliably with essentially all hosts, but it would not pass USB certification, so treat it as a bench/hobby-grade solution.
One extra gotcha if you use a USB-C connector: a C source won't enable VBUS until it detects a device, so you must add two separate 5.1 kΩ Rd pull-downs, one on CC1 and one on CC2 (don't share a single resistor between them — that breaks with e-marked cables). Without them the board will appear to work on A-to-C cables but be completely dead on C-to-C cables and modern laptop ports.
