I'm working on a project that requires extremely low power consumption with a QuickLogic FPGA. I'm using an EOS S3 and aiming for battery-powered operation. I've already implemented clock gating and voltage scaling where possible.
I'm looking for advice and best practices on further reducing power consumption. Specifically:
* **Power-down modes:** What are the most effective power-down modes for the EOS S3, and how can I trigger them effectively based on system activity? Are there any examples of using these modes in conjunction with interrupts?
* **Logic optimization:** Are there specific coding styles or synthesis directives that significantly reduce power consumption in QuickLogic FPGAs? Should I focus on minimizing transitions or reducing the overall gate count?
* **Peripheral management:** I'm using the SPI and I2C peripherals. Are there any power-saving strategies for managing these peripherals when they are not actively in use? Should I completely disable them or use a low-power mode?
* **Memory access:** I'm using internal SRAM. Are there any techniques to minimize power consumption during memory access? Are there recommendations on how to arrange data in memory to improve power efficiency?
* **Debugging Tools:** Which QuickLogic debugging tools are useful in measuring power consumption.
Any insights, code snippets, or pointers to relevant documentation would be greatly appreciated. I'm also interested in hearing about any real-world experiences others have had with optimizing power consumption on QuickLogic FPGAs. Thanks in advance!.
Power Consumption Optimization Techniques.
Reducing power consumption is essential for improving efficiency, extending battery life, lowering operational costs, and meeting sustainability goals. Below are widely used and effective power optimization techniques across hardware, software, and system levels. Ragdoll Hit
harrydaily
nytwordlehints
For EOS S3 low-power optimization, make full use of Deep Sleep and Hibernate modes, triggered by RTC or GPIO wake-up interrupts. In synthesis, enable power optimization options and use enable signals to gate idle logic. Peripherals like SPI and I2C should be completely disabled via PD_PERSIST registers when not in use. For SRAM access, use burst mode to reduce power consumption. For debugging, the QuickLogic PowerSense tool combined with an oscilloscope current probe can be used for real-time measurements. For specific register configurations, refer to the EOS S3 Ultra Low Power Design Guide.
Howskit Some
Make the most of Deep Sleep and Hibernate modes, which are activated by RTC or GPIO wake-up interrupts, for EOS S3 low-power optimisation. In synthesis, turn on power optimisation features and gate idle logic with enable signals. When not in use, peripherals like SPI and I2C should be fully disabled using PD_PERSIST registers. basketball stars
We’ve developed a battery‑powered keyword‑detection solution that uses an FSM‑based state machine to dynamically adjust the clock frequency and enable or disable peripherals to achieve low‑power operation. This will only work if you are using FreeRTOS. I’ll work on providing a video and supporting documentation that should help illustrate the approach.
Regarding the SRAM: each 32 KB block is implemented as an independent power island, allowing unused memory sections to be fully powered down, which significantly reduces overall power consumption.
Please give me a few days to gather and share the additional information.
skillfuleyeglasses
Hi biz,lopvapork wrote: ↑Tue May 13, 2025 11:02 pm I'm working on a project that requires extremely low power consumption with a QuickLogic FPGA. I'm using an EOS S3 and aiming for battery-powered operation. I've already implemented clock gating and voltage scaling where possible.
For ultra-low-power on EOS S3: use deep sleep/retention modes triggered by interrupts for wake-on-event, minimize logic transitions and gate count, apply clock gating, and disable or low-power idle SPI/I2C peripherals. For SRAM, group frequently accessed data and limit simultaneous reads/writes. QuickLogic’s Quantum Debugger and power estimation tools help monitor consumption. Focus on activity reduction and interrupt-driven wake for the biggest power savings.
