marbu
Hey,
I would like to know if
Thank you!
plowhank
level devil
AnnJennings
alehyha
Despite its simple controls, monkey mart offers surprisingly deep idle management systems that reward smart planning and efficient store organization.
marryhile1208
alehyha wrote: Thu Jan 29, 2026 7:21 am In Companion Mode, the EOS is typically booted by an external host. In this case, the firmware must be loaded via the SPI slave interface on every power-up, as the EOS does not automatically boot a persistent image by itself.
THANKS
George436
Companion Mode can be a bit confusing from the manual alone, so clearer documentation and a practical boot/loading example from an external host processor would definitely help developers working with EOS.
