We have an odd problem. We need to produce a small serie (~50 Pices) of QL-8x12B-PL68C.
We have mostly all we need some we have
- The chips,
- A PC running with Windos 3.11(with a serial interfave)
- A QP-QL84 with the necessary adapter
- The Sources of the Programming and the CHP file
- The Quickworks software (but the downloaded 9.4.1 version is not installable under 3.11 as described in the old doc, and not supporting a a programmer)
- QuickPro is runnung udner new systems, but probaly not supporting the QP-PL84  (or is it ?)
Is there a way to get the old old old software which was running under windows 3.1 (3.11) just to burn the Chips.
(we could find no-one still having a programming environment for the QL8x12B-0PL68C)
Thenks for hints or help
Ralph
						Does QP-PL84 works with QuickPro
Unfortunately, the pASIC1 family was EOL in Jan'2005 and we no-longer have a programmer that supports these devices.
I believe that you would need the designer pro programmer
We can guarantee the quality of if the devices would program successfully, but I found this details on the web
https://www.wesource.com/electronic-com ... 0885-5/22/
You could also check with the old QuickLogic third-party center in the UK called Action Circuit, in Luton to see if they still have programming equipment.
				scenecabin
Ralph is trying to program ~50 QL-8x12B-PL68C chips using vintage tools: he has the chips, programmer, sources, and a Windows 3.11 PC, but the Quickworks 9.4.1 software won’t run on it or support the programmer. He's seeking the original Windows 3.1-compatible software to burn the chips.MIPECAG wrote: ↑Fri Jul 29, 2022 4:12 pm Hi
- The chips,
Ralph
