8-bit ECUs for FIR filters
QuickLogic was the first FPGA company to add DSP into the FPGA with the EclipsePlus family. Unfortunately, these DSP’s are only 8-bits and they need to use FPGA routing to cascade together. I don’t believe that it would be very efficient to implement 32x32.
Another alternative is the EOS S3, which has ~900 Logic elements and two dedicated 32x32 Multipliers connected to the FPGA.
Page 62 and 63 of the datasheet at https://www.quicklogic.com/wp-content/u ... t-2020.pdf
Multiplier selection
Built-in signed multipliers are also available in the on-chip programmable logic. The multiplier relieves the use of logic to implement such functions. There are two instances embedded in the on-chip programmable logic. The multiplier can be configured as one 32x32 bit multiplier or two 16x16 bit multipliers. A block diagram of the multiplier is shown on page 63.
As this device also has Cortex M4-F and dual PDM or I2S MIC interface it might be a better choice.
The PDM / I2S is ideally suited for low power voice applications.
Is there a reason for looking at PolarPro or EclipsePlus?
The EOS S3 family, with its Cortex M4-F, dual PDM or I2S MIC interface, and dedicated multipliers, seems to offer advantages such as improved efficiency and suitability for low-power voice applications. The ability to configure the multipliers as one 32x32 bit multiplier or two 16x16 bit multipliers provides flexibility in design.
heardle
heardle
