Looking for documentation about eFPGA macrocells (EOS-S3)
Martoni
When I launch synthesis with QORC commands I get log files that give occupancy statistics in file «/opt/qorc-sdk/qf_apps/qf_helloworldhw/fpga/rtl/build/helloworldfpga_synth.log» (for helloworld app) :
13. Printing statistics.
=== helloworldfpga ===
   Number of wires:               1055
   Number of wire bits:           1055
   Number of public wires:        1055
   Number of public wire bits:    1055
   Number of memories:               0
   Number of memory bits:            0
   Number of processes:              0
   Number of cells:                119
     ASSP                            1
     BIDIR_CELL                      3
     C_FRAG                         13
     F_FRAG                          1
     Q_FRAG                         44
     T_FRAG                         57
route.log give more cells :
Pb types usage...
  PB-SYN_GND        : 1
   GND              : 1
  PB-BIDIR          : 3
   BIDIR            : 3
    OUTPUT          : 3
     bidir          : 3
     outpad         : 3
  PB-ASSP           : 1
   ASSP             : 1
  PB-LOGIC          : 56
   LOGIC            : 56
    FRAGS           : 56
     c_frag_modes   : 56
      SINGLE        : 13
       c_frag       : 13
      SPLIT         : 43
       b_frag       : 43
       t_frag       : 14
     f_frag         : 1
     q_frag_modes   : 44
      INT           : 43
       q_frag       : 43
      EXT           : 1
       q_frag       : 1
  PB-SYN_VCC        : 1
   VCC              : 1
Device Utilization: 0.05 (target 1.00)
	Physical Tile TL-LOGIC:
	Block Utilization: 0.06 Logical Block: PB-LOGIC
	Physical Tile TL-RAM:
	Block Utilization: 0.00 Logical Block: PB-RAM
	Physical Tile TL-MULT:
	Block Utilization: 0.00 Logical Block: PB-MULT
	Physical Tile TL-BIDIR:
	Block Utilization: 0.09 Logical Block: PB-BIDIR
	Physical Tile TL-CLOCK:
	Block Utilization: 0.00 Logical Block: PB-CLOCK
	Physical Tile TL-SDIOMUX:
	Block Utilization: 0.00 Logical Block: PB-SDIOMUX
	Physical Tile TL-GMUX:
	Block Utilization: 0.00 Logical Block: PB-GMUX
	Physical Tile TL-ASSP:
	Block Utilization: 1.00 Logical Block: PB-ASSP
	Physical Tile TL-SYN_VCC:
	Block Utilization: 1.00 Logical Block: PB-SYN_VCC
	Physical Tile TL-SYN_GND:
	Block Utilization: 1.00 Logical Block: PB-SYN_GND
Where can I found documentation about this cells ?
Martoni
I can't find eFPGA mapping of macrocells in this datasheet or this.
The reference manual has a section of the FPGA. If you want to understand how to interface the FPGA I would suggest the following additional resources
https://github.com/coolbreeze413/qorc-onion-apps
This has a range of basic examples of how to interface the EOS device with your FPGA design.
A video tutorial is also available at https://www.quicklogic.com/products/soc ... ontroller/
Then select the SymbiFlow with QuickFeather – A simple FPGA Programming Example video
Additional documentation is also available at https://quicklogic-quicklogic-fpga-tool ... ecoun.html
I will update with the naming of the Logic cell fragmentation.
The FPGA Logic Cell in EOS S3 can be fragmented into four pieces
[img][
PP3 .png (23.93 KiB) Viewed 399359 times
/img]
The frag F is also referred to as b.
Boiaten
The architecture of the macrocells and how they interact with the rest of the device
Timing constraints and optimization techniques for these macrocells
Best practices for configuring and programming the eFPGA using the available tools
If anyone has any experience with the EOS-S3 eFPGA and could provide some insights or recommendations, I would be very grateful.
Papa's Pizzeria
EmmaAlva
Optimal methods for eFPGA configuration and programming using the provided toolset tiny fishing
muakan01
The Body to Body Massage in Dwarka offers deep connection and thorough relaxation. Warm oil, skilled technique, and a private setting create a unique experience. Many clients return for the quality and care provided.
ritafoster
Looking for documentation about eFPGA macrocells (EOS-S3) is so amazing and that is the reason people are here to learn how it can help them to resolve these issues. When I visit the garage builder Weatherford TX it bring the amazing ideas I want to know and it help me out to provide great results.
