Hey,
I would like to know if
Thank you!
level devil
level devil
AnnJennings
Despite its simple controls, monkey mart offers surprisingly deep idle management systems that reward smart planning and efficient store organization.
marryhile1208
THANKSalehyha wrote: ↑Thu Jan 29, 2026 7:21 am In Companion Mode, the EOS is typically booted by an external host. In this case, the firmware must be loaded via the SPI slave interface on every power-up, as the EOS does not automatically boot a persistent image by itself.
Companion Mode can be a bit confusing from the manual alone, so clearer documentation and a practical boot/loading example from an external host processor would definitely help developers working with EOS.
Alfieolloway
I ran into this exact hurdle when integrating the EOS S3 with an external MCU. Because the EOS relies on volatile SRAM, loading the firmware over SPI Slave on every cold boot is mandatory unless you switch to Standalone mode using an external SPI Flash. For practical implementation, I found QuickLogic's open-source qorc-sdk on GitHub far more useful than the reference manual for code examples and boot protocol sequences.
The Cps Test proves that online entertainment doesn't always need impressive graphics or complicated mechanics.
That's a tricky one! System startup with an external host processor can definitely be a maze, and the sparse documentation doesn't help. I've encountered similar issues when trying to optimize boot sequences. Have you tried looking for community-made examples or forums dedicated to advanced embedded topics? Sometimes the best insights come from fellow developers. It reminds me of the strategic thinking you need in games like Slither io to get ahead!"
