I'm using Windows subsystem for Linux (Ubuntu 18.04 LTS) following the video on Quicklogic website below.
https://www.youtube.com/embed/1lhxTlOSFPA
I installed ARM GNU GCC toolchain and make already, when I try to make the project downloaded from github (https://github.com/QuickLogic-Corp/qorc-sdk), I hit build error:
jack@XPS13-JZHANG:/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project$ make
"shell Bash"
Building using GCC Toolchain
Using Linux GNU GCC Toolchain
make -f makefiles/Makefile_Startup
make[1]: Entering directory '/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project'
Compile: /mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project/../../../HAL/startup/startup_EOSS3B_GCC.c
/bin/sh: 1: /usr/bin /mnt/c/Program Files (x86)/GNU Tools ARM Embedded/7 2017-q4-major/bin.exe/arm-none-eabi-gcc: not found
makefiles/Makefile_Startup:15: recipe for target '/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project/output/startup_EOSS3B_GCC.o' failed
make[1]: *** [/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project/output/startup_EOSS3B_GCC.o] Error 127
make[1]: Leaving directory '/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project'
Makefile:40: recipe for target 'Startup' failed
make: *** [Startup] Error 2
I found arm-none-eabi-gcc.exe existed in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major\bin, but is that supposed to be a different path?
Any idea on this? Thanks
qorc-sdk build error
It seems like incorrect path issue.
I changed toolchain pach in config.mk to specify the correct path as below.
export TC_PATH=/mnt/c/"Program Files (x86)"/"GNU Tools ARM Embedded"/"7 2017-q4-major"/bin
But still got build error.
"shell Bash"
/bin/sh: 1: Syntax error: "(" unexpected
make[1]: *** [/mnt/c/QLogic/Products/FOSS/M4/FreeRTOS/qorc-sdk/qf_apps/qf_helloworldsw/GCC_Project/output/startup_EOSS3B_GCC.o] Error 2
What is the correct way to specify the path with spaces in it?
"shell Bash"
murthy.vedula
It appears that you are combining Windows and Linux environment. Please install GNU toolchain on the Linux subsystem, refer the Video and the README.md.
I'm using WSL and installed arm-none-eabi-gcc already.
I did following changes in the config.mk file to change it to my own toolchain directory.
#export TC_PATH = $(subst /arm-none-eabi-gcc,,$(FIND_TOOL_DIR)) <<--- disabled the define
export TC_PATH=/usr/bin/ <<--- point it to my toolchain directory
Then the build works.
Jack
Jack
