Hi everyone, I’m working on a low-power camera application using the EOS S3, and I’m trying to optimize power consumption during intermittent image capture (e.g., capturing 1 frame every few seconds). Currently, I see higher-than-expected power draw even when the system is mostly idle between captures.
Has anyone here successfully minimized power usage in a similar use case? Specifically:
Which sleep mode works best between captures?
Are there recommended ways to fully gate the camera interface or MIPI block when not in use?
Any tips for reducing wake-up latency without increasing overall power consumption?
Appreciate any insights or examples from real projects!
EOS S3 Camera Power Optimization
What sleep mode are you currently using between captures?
gordonpiper
I ran into the same issue on EOS S3, and the key insight for me was that “idle” isn’t really low power unless you explicitly shut things down.
Looking for the best escorts in GTB Nagar? We've got a wide range of sophisticated companions to match your specific preferences. Our GTB Nagar Escorts Service goal is to create a relaxing atmosphere where you can let go and feel at ease. Try our high-end agency to really experience the difference in quality and client care.
