Hi All,
I m able to build and download the firmware to Quickfeather board.
I have used "qf_ssi_ai_app" application which generated qf_ssi_ai_app.bin, after flash of this bin the  Serial Port is not detected.
Environment : Windows  wth ecllipse IDE
Ashok R
						Quickfeather Serial Port not detected
Simple Streaming capture mode requires the use of the UART pins on the QuickFeather, so you need a USB to TTL serial adapter to connect to QF.
There is some detail in below link.
https://www.hackster.io/gatoninja236/ge ... iml-9881a3
