EOS S3 Interrupt Numbers
typedef enum
/****** Cortex-M4 Processor Exceptions Numbers ****************************************************************/
NonMaskableInt_IRQn = -14, /*!< 2 Non Maskable Interrupt */
MemoryManagement_IRQn = -12, /*!< 4 Cortex-M4 Memory Management Interrupt */
BusFault_IRQn = -11, /*!< 5 Cortex-M4 Bus Fault Interrupt */
UsageFault_IRQn = -10, /*!< 6 Cortex-M4 Usage Fault Interrupt */
SVCall_IRQn = -5, /*!< 11 Cortex-M4 SV Call Interrupt */
DebugMonitor_IRQn = -4, /*!< 12 Cortex-M4 Debug Monitor Interrupt */
PendSV_IRQn = -2, /*!< 14 Cortex-M4 Pend SV Interrupt */
SysTick_IRQn = -1, /*!< 15 Cortex-M4 System Tick Interrupt */
/****** Specific Interrupt Numbers **********************************************************************/
SwInt2_IRQn = 0,
SwInt1_IRQn = 1,
Reserved1_IRQn = 2,
Ffe0Msg_IRQn = 3,
FbMsg_IRQn = 4,
Gpio_IRQn = 5,
SramSleep_IRQn = 6,
Uart_IRQn = 7,
Timer_IRQn = 8,
CpuWdtInt_IRQn = 9,
CpuWdtRst_IRQn = 10,
BusTimeout_IRQn = 11,
Fpu_IRQn = 12,
Pkfb_IRQn = 13,
Reserved_I2s_IRQn = 14,
Reserved_Audio_IRQn = 15,
SpiMs_IRQn = 16,
CfgDma_IRQn = 17,
PmuTimer_IRQn = 18,
AdcDone_IRQn = 19,
RtcAlarm_IRQn = 20,
ResetInt_IRQn = 21,
Ffe0_IRQn = 22,
FfeWdt_IRQn = 23,
ApBoot_IRQn = 24,
Ldo30_pg_IRQn = 25,
Ldo50_pg_IRQn = 26,
Sram_to_IRQn = 27,
Lpsd_IRQn = 28,
Dmic_IRQn = 29,
Reserved2_IRQn = 30,
Sdma_Done1_IRQn = 31,
Sdma_Done2_IRQn = 32,
Sdma_Done3_IRQn = 33,
Sdma_Done4_IRQn = 34,
Sdma_Done5_IRQn = 35,
Sdma_Done6_IRQn = 36,
Sdma_Done7_IRQn = 37,
Sdma_Done8_IRQn = 38,
Sdma_Done9_IRQn = 39,
Sdma_Done10_IRQn = 40,
Sdma_Done11_IRQn = 41,
Ap_Pdm_Clock_On_IRQn = 42,
Ap_Pdm_Clock_Off_IRQn = 43,
Dmac0_Block_Done_IRQn = 44,
Dmac0_Buffer_Done_IRQn = 45,
Dmac1_Block_Done_IRQn = 46,
Dmac1_Buffer_Done_IRQn = 47,
Sdma_Done0_IRQn = 48,
Sdma_Err_IRQn = 49,
I2SSlv_M4_IRQn = 50,
Lpsd_Voice_Off_IRQn = 51,
Dmic_Voice_Off_IRQn = 52
} IRQn_Type;
Thanks @gmartin for the answers. I am looking forward to more answers about this one as I have the same problem.
atlanta mobile detailing
