Should bug reports regarding the 'official' EOS-S3 toolchain be submitted here in the forums, or at the QuickLogic github repo[1] ?
Asking because the above repo hasn't been updated in about 2 years...
Some of the EOS-S3 constraint issues I've encountered have been fixed in the newer F4PGA toolchain[2], but its EOS-S3 flow is labeled as "currently unsupported" [3].
-Brian
[1] https://github.com/QuickLogic-Corp/quic ... -toolchain
[2] https://github.com/chipsalliance/f4pga
[3] https://f4pga.readthedocs.io/en/latest/f4pga/Usage.html
"Quicklogic EOS-S3 (currently unsupported, provided only for development purposes)"
Bug reporting for EOS-S3 FPGA toolchain
The QuickLogic support for EOS S3 has been rolled into the f4PGA release at https://github.com/chipsalliance/f4pga-examples
Instructions on installing and running the demo is available at https://f4pga-examples.readthedocs.io/e ... tting.html
Example project is available at https://github.com/search?q=qorc-onion- ... positories
You are correct f4PGA are not supporting EOS S3, so please log any issues here and QuickLogic will look to see how we can support.
--Robert
--Robert
chilechevrolet
I’d probably post the bug reports here first, especially if the GitHub repo hasn’t seen any updates in two years. It would be good to know whether the EOS-S3 flow is still officially maintained or if development has effectively moved elsewhere.
I’d probably report EOS-S3-specific issues in this forum, especially since the F4PGA documentation says the EOS-S3 flow is unsupported. That way QuickLogic can see problems that might be specific to their device support.
For general F4PGA issues, the GitHub repo would make more sense. It would also be useful to know whether there’s a recommended version/commit of F4PGA for EOS-S3 development.
