EOS S3 Interrupt Numbers
btashton
gmartin
typedef enum
/******  Cortex-M4 Processor Exceptions Numbers ****************************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                                          */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M4 Memory Management Interrupt                           */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M4 Bus Fault Interrupt                                   */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M4 Usage Fault Interrupt                                 */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M4 SV Call Interrupt                                    */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M4 Debug Monitor Interrupt                              */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M4 Pend SV Interrupt                                    */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M4 System Tick Interrupt                                */
/******  Specific Interrupt Numbers **********************************************************************/
  SwInt2_IRQn                    = 0,
  SwInt1_IRQn                            = 1,
  Reserved1_IRQn                     = 2,
  Ffe0Msg_IRQn                = 3,
  FbMsg_IRQn                        = 4,
  Gpio_IRQn                   = 5,
  SramSleep_IRQn              = 6,
  Uart_IRQn                   = 7,
  Timer_IRQn                  = 8,
  CpuWdtInt_IRQn              = 9,
  CpuWdtRst_IRQn              = 10,
  BusTimeout_IRQn             = 11,
  Fpu_IRQn                    = 12,
  Pkfb_IRQn                   = 13,
  Reserved_I2s_IRQn           = 14,
  Reserved_Audio_IRQn         = 15,
  SpiMs_IRQn                  = 16,
  CfgDma_IRQn                 = 17,
  PmuTimer_IRQn               = 18,
  AdcDone_IRQn                = 19,
  RtcAlarm_IRQn               = 20,
  ResetInt_IRQn               = 21,
  Ffe0_IRQn                   = 22,
  FfeWdt_IRQn                 = 23,
  ApBoot_IRQn                 = 24,
  Ldo30_pg_IRQn               = 25,
  Ldo50_pg_IRQn               = 26,
  Sram_to_IRQn                = 27,
  Lpsd_IRQn        = 28,
  Dmic_IRQn        = 29,
  Reserved2_IRQn                                          = 30,
  Sdma_Done1_IRQn                                     = 31,
  Sdma_Done2_IRQn                                     = 32,
  Sdma_Done3_IRQn                                     = 33,
  Sdma_Done4_IRQn                                     = 34,
  Sdma_Done5_IRQn                                     = 35,
  Sdma_Done6_IRQn                                     = 36,
  Sdma_Done7_IRQn                                     = 37,
  Sdma_Done8_IRQn                                     = 38,
  Sdma_Done9_IRQn                                     = 39,
  Sdma_Done10_IRQn                    = 40,
  Sdma_Done11_IRQn                    = 41,
  Ap_Pdm_Clock_On_IRQn                          = 42,
  Ap_Pdm_Clock_Off_IRQn       = 43,
  Dmac0_Block_Done_IRQn          = 44,
  Dmac0_Buffer_Done_IRQn      = 45,
  Dmac1_Block_Done_IRQn       = 46,
  Dmac1_Buffer_Done_IRQn      = 47,
  Sdma_Done0_IRQn                                     = 48,
  Sdma_Err_IRQn                                 = 49,
  I2SSlv_M4_IRQn                                = 50,
  Lpsd_Voice_Off_IRQn                  = 51,
  Dmic_Voice_Off_IRQn                 = 52
} IRQn_Type;
btashton
gmartin
Looking to get the information you requested. We will be updating our TRM as appropriate, but will reply separately with the information you requested.
gmartin
btashton
Really appreciate it, this is the information I was looking for.
mihirmane
Thanks..........
Apply for photography jobs, video editing jobs, musicians jobs, singing jobs, acting jobs in India. jobs for models
jessicabyrne11
Fantastic forum content! Do you have any suggestions for aspiring and useful writers? I always visit your many others forums and retrieve everything you post here but I never commented but today when I saw this topic release, I couldn’t stop myself from commenting here. Thank you and good luck for new posts. assignment help in Australia - Assignment Help in Melbourne
jameswick11
Contact:
Use finance assignment help to finish your finance or accounting papers without messing yourself. You will get assured solutions to your numerical questions within your defined date or time.
davidarcane
Thank you for sharing such a post! Truthful Betway reviews are what every newbie needs. That is why I visited this page to learn all the important aspects of modern esports betting.
