EOS S3 Camera Power Optimization
lylybrown
Hi everyone, I’m working on a low-power camera application using the EOS S3, and I’m trying to optimize power consumption during intermittent image capture (e.g., capturing 1 frame every few seconds). Currently, I see higher-than-expected power draw even when the system is mostly idle between captures.
Has anyone here successfully minimized power usage in a similar use case? Specifically:
Which sleep mode works best between captures?
Are there recommended ways to fully gate the camera interface or MIPI block when not in use?
Any tips for reducing wake-up latency without increasing overall power consumption?
Appreciate any insights or examples from real projects!
nancy266
great post
