At this point I'm tempted to just buy another board and throw this one away, since the board just doesn't boot up at all without using a debugger. But I thought I would post my question here to see if I can get any advice.
After receiving the board, I tried to power it on by connecting it to my laptop with a micro USB cable. However, it doesn't seem to be powering on the way I expect it to. When I try to connect it to my laptop, I see:
- The white LED flashes ON, and then fades to OFF.
- If I press the RESET button or USER button, I don't see anything happen (i.e. the LED stays OFF).
Note that the bootstrap jumpers are not on the board at this point. So I think the board is bricked, and decide to try and recover using the instruction here: https://www.youtube.com/watch?v=Q5GIZUs ... e=youtu.be
I reattach the bootstrap jumpers and connect my JLink to the board.
I follow the above instructions and am able to successfully get the bootloader to talk to TinyFPGA script, and it seems like there is no complaints and I can program the software to the unit. e.g. I tried these commands to program the images to the board, which appears as though there are no complaints (but perhaps I missed something here):
python tinyfpga-programmer-gui.py --bootloader ..\quickfeather-initial-binaries\qf_bootloader.bin --mode m4
python tinyfpga-programmer-gui.py --bootfpga ..\quickfeather-initial-binaries\qf_bootfpga.bin --mode m4
python tinyfpga-programmer-gui.py --m4app ..\quickfeather-initial-binaries\qf_helloworldsw.bin --mode m4Code: Select all
python tinyfpga-programmer-gui.py --update --mfgpkg ..\quickfeather-initial-binaries --mode m4
CLI mode
ports = ['COM29 (QuickFeather)'] 1
Using port COM29 (QuickFeather)
Skipping programming because CRC matches for ..\quickfeather-initial-binaries/qf_helloworldsw.bin
Skipping programming because CRC matches for ..\quickfeather-initial-binaries/qf_bootloader.bin
Skipping programming because CRC matches for ..\quickfeather-initial-binaries/qf_bootfpga.bin
operating mode : [m4]
setting appfpga inactive
image_info is already set correctly, not writing again
setting m4app active
image_info is already set correctly, not writing againBut I don't see any improvement once I remove the jumpers and try to reconnect the board.
In addition, I found that if I connect to the board over JLink and reset & run the board, the demo app does run (i.e. I can control the LEDs and read the state of the user button). But only if I've run the board using JLink.
One other observation is that in JLink, when I perform the reset command, I see some text that appears to suggest my board is currently in reset (i.e. "S_RESET_ST never gets cleared. CPU seems to be kept in reset forever."), which I didn't see in the Youtube video, so perhaps a hardware issue?
J-Link>r
Reset delay: 0 ms
Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Reset: S_RESET_ST never gets cleared. CPU seems to be kept in reset forever.
Reset: Using fallback: Reset pin.
Reset: Reset device via reset pin
Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
Reset: Reconnecting and manually halting CPU.
Found SW-DP with ID 0x2BA01477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.Any thoughts on something I should try or anything I missed? Would appreciate any advice on this.
