Quick feather region rom overflow
As picture attached, rom size is not enough after adding some sensor drivers. How to add more space in rom region? I found quickfeather.ld in GCC_Project folder and the origin for ROM section is 0x00. As my understanding, 0x00 is for bootloader and 0x80000 is for m4app. Is quickfeather.ld the right file for qf_ssi_ai_app?
MEMORY
rom (rx) : ORIGIN = 0x00000000, LENGTH = 0x0002C000
ram (rwx) : ORIGIN = 0x2002C000, LENGTH = 0x0003c800
spiram (rw) : ORIGIN = 0x20063800, LENGTH = 0x0000800
HWA (rw) : ORIGIN = 0x20064000, LENGTH = 0x00018000
shm : ORIGIN = 0x2007C000, LENGTH = 0x00004000
BTW, should we modify tinyfpga-programmer-gui.py to meet the changes of rom region in .ld file?
It works after change the rom length and modify the origin address for the other section in quickfeather.ld.
MEMORY
rom (rx) : ORIGIN = 0x00000000, LENGTH = 0x00040000
ram (rwx) : ORIGIN = 0x20040000, LENGTH = 0x0003c800
spiram (rw) : ORIGIN = 0x2007c800, LENGTH = 0x0000800
HWA (rw) : ORIGIN = 0x2007d000, LENGTH = 0x00018000
shm : ORIGIN = 0x20095000, LENGTH = 0x00004000
Memory region Used Size Region Size %age Used
rom: 206228 B 256 KB 78.67%
ram: 193744 B 242 KB 78.18%
spiram: 0 GB 2 KB 0.00%
HWA: 0 GB 96 KB 0.00%
shm: 0 GB 16 KB 0.00%
Convert ELF to BIN
Create text symbol table.
make[1]: Leaving directory '/mnt/d/GitHub/qorc-sdk/qf_apps/qf_ssi_ai_app/GCC_Project'
spurgenotion
frankie wrote: Wed Aug 24, 2022 3:37 am It works after change the rom length and modifygeometry dash world the origin address for the other section in quickfeather.ld.
MEMORY
Convert ELF to BIN
Many thanks for that solution.
designdev
frankie wrote: Wed Aug 24, 2022 3:37 am It works after change the rom length and modify the origin address for the other section in quickfeather.ld.
MEMORY
Convert ELF to BIN
Thanks for the tip — changing the ROM length and origin address did the trick! Just to clarify: is there a recommended way to calculate safe values for other sections like `spiram` or `HWA` if usage increases?
I love minimal mehndi design so much.
