Bunch of noises in the audio data
Posted: Tue Feb 09, 2021 3:02 pm
by juanyi
I was trying out some simple spelling to the quickfeather. The audio data collected in DCL contains a lot of noises, did anybody know how to filter/remove the noises or configure/fine-tune the onboard Infineon mic? The model failed miserably with this kind of data.
Re: Bunch of noises in the audio data
Posted: Tue Feb 09, 2021 11:51 pm
by shimemar
Hello
I also confirmed, but the situation is the same.
It's the same even if I attach a microphone to the outside, so I'm giving up using it now.
Posted: Sat Feb 13, 2021 4:33 pm
by juanyi
shimemar wrote: ↑Tue Feb 09, 2021 11:51 pm Hello
So you attach a 3rd party microphone?
I'm hoping somebody from QuickLogic to get us through this but still no reply from them, I wonder do they look at this forum or not. Anybody else having the same issue here?
Posted: Thu Feb 18, 2021 12:19 am
by gpcm
Same issue here!
Posted: Thu Feb 18, 2021 9:56 pm
by anthony-ql
Please let us know which QORS_SDK version you used for collecting audio data. The latest tag version 1.7.0 has improvement to eliminate the noises seen in some systems. Link https://github.com/QuickLogic-Corp/qorc ... tag/v1.7.0
Posted: Fri Feb 19, 2021 5:24 am
by juanyi
I was using v1.5.0 before. Same noise issue even I tried v1.7.0. Could it be some fine-tuning or pre-processing needed for the MIC?
Posted: Fri Feb 19, 2021 6:03 pm
by gpcm
I am using version 1.8
Posted: Mon Feb 22, 2021 4:22 pm
by anthony-ql
The issue is reported to internal team. We are working on validating the issue and will look for solution. Stay tune.
Posted: Mon Mar 08, 2021 5:28 am
by jmoore
This should be fixed in the latest DCL release (2020.10.6, or you may see an update for 2020.10.7 come Monday the 8th.)
Posted: Tue Mar 09, 2021 12:23 pm
by juanyi
Yes, thanks for the remedy! It audio data is clean now.
