Hello There!
I am working on a project where I am collecting data from 3 sensors, which I need to make inferences. But due to me being unable to figure out how to program the Quickfeather for my requirement, I am stuck. I watched the first webinar but haven't been able to figure out still. I have 2 analog sensors, one of them working in 0-50mV range, and a digital sensor that need to be interfaced with the Quickfeather. I have tried to find relevant documentation but have been really unsuccessful, mostly due to my lack of experience in regards with Embedded C and RTOS. All I managed was a page mentioning about GPIO and videos about DCL and requirements of modifications to the .ssf file. Can anyone please enlighten me what I could do to move forward in my project? Any help or suggestion is much appreciated.
Thanks!
simple GPIO and SensiML interfacing
Hello @jmoore. I have been continuing my work on my project. I used an ADS1015 to stream 3 sensors' data to the Quickfeather. I managed to follow the documentation for the Simple Streaming Interface project and despite the documentation not being in very detailed, I managed to make the necessary changes to remove multiple errors. But when I am executing the make command, it exits with an error. I did a make clean and make again but I am still getting the same error. I have attached a screenshot of the terminal. Please offer your expertise with what I can do to solve this error as I am unable to figure out the issue here.
- Attachments
- Make command output
- Screenshot from 2021-02-14 16-54-50.png (318.44 KiB) Viewed 20596 times
From the error It appears that functions in SparkFun_ADS1015_Arduino_Library.cpp are compiled twice. Please verify that these functions are included in only one source file.
Hello!
@murthy.vedula thanks for your input. I have been trying to figure out the issue, but I followed the guide for interfacing the ADS1015 on github again and got the same results. If it isn't too much to ask, could you please take a look at my C++ files that are supposed to be modified according to the guide. Also I am attaching a log file with the complete teminal output of the make command. Could you please give me specific directions how to correct this. I don't have much experience with embedded C but was really excited by the competition theme and my project idea and would like to definitely complete it.
Thanks!
Thanks!
- Attachments
- log.zip
- (5.18 KiB) Downloaded 558 times
- source_files.zip
- (12.97 KiB) Downloaded 563 times
@Shapy
Reviewed the source_files.zip, please remove the following Line#39 in sensor_ssss.cpp
#include "SparkFun_ADS1015_Arduino_Library.cpp"
The above statement is causing this to be compiled twice.
Hello @murthy.vedula!
I am trying to use an Adafruit ADC with it's specific modified Cpp library for reading analog sensor values and have made the necessary changes indicated online and the 1st webinar. But I am not receiving any JSON string to read on serial. Could u suggest any possible areas where I might have messed up to cause the JSON string not coming at all? Can only Sparkfun ADCs be used?
Thanks!
Thanks!
