symbiflow_write_bitstream fails in example counter_16bit
Posted: Wed Jan 27, 2021 8:08 pm
I'm trying to run the counter_16bit example.
The
(base) gjones@geoff-VB-Ubuntu:/usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit$ ql_symbiflow -compile -src $PWD -d ql-eos-s3 -t top -v counter_16bit.v -p chandalar.pcf -P PD64 -s counter_16bit.sdc
-compile
-src
-d
ql-eos-s3
-t
top
-v
counter_16bit.v
-p
chandalar.pcf
-P
PD64
-s
counter_16bit.sdc
verilog files: counter_16bit.v
Running Synth->Pack->Place->Route
cd build && symbiflow_pack -e top.eblif -d ql-eos-s3_wlcsp -s /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/counter_16bit.sdc 2>&1 > /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/build/top.log
cd build && symbiflow_place -e top.eblif -d ql-eos-s3_wlcsp -p /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/chandalar.pcf -n top.net -P PD64 -s /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/counter_16bit.sdc 2>&1 > /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/build/top.log
cd build && symbiflow_route -e top.eblif -d ql-eos-s3_wlcsp -s /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/counter_16bit.sdc 2>&1 > /usr/local/symbiflow/quicklogic-arch-defs/tests/counter_16bit/build/top.log
cd build && symbiflow_write_fasm -e top.eblif -d ql-eos-s3_wlcsp
VPR FPGA Placement and Routing.
Version: 8.1.0-dev+dadca7ecf
Revision: v8.0.0-rc2-2894-gdadca7ecf
Compiled: 2020-10-14T15:08:54
Compiler: GNU 7.3.0 on Linux-4.15.0-1028-gcp x86_64
Build Info: Release IPO VTR_ASSERT_LEVEL=2
... (lots of messages. No errors)
Checking to ensure routing is legal...
Completed routing consistency check successfully.
Serial number (magic cookie) for the routing is: -397596549
Circuit successfully routed with a channel width factor of 100.
Incr Slack updates 1 in 0.000128178 sec
Full Max Req/Worst Slack updates 1 in 5.419e-05 sec
Incr Max Req/Worst Slack updates 0 in 0 sec
Incr Criticality updates 0 in 0 sec
Full Criticality updates 1 in 0.000173351 sec
Writing Implementation FASM: top.fasm
The entire flow of VPR took 19.1337 seconds.
FASM extra: top_fasm_extra.fasm
cd build && symbiflow_write_bitstream -d ql-eos-s3_wlcsp -f top.fasm -P PD64 -b top.bit
Writing bitstream ...
/usr/local/symbiflow/conda/lib/python3.7/site-packages/fasm/parser/__init__.py:27: RuntimeWarning:
Falling back on slower textX parser implementation:
ImportError: cannot import name 'antlr_to_tuple' from 'fasm.parser' (/usr/local/symbiflow/conda/lib/python3.7/site-packages/fasm/parser/__init__.py)
Please install all dependencies and reinstall with:
pip uninstall
pip install -v fasm
' pip install -v fasm'.format(e), RuntimeWarning)
The
-compile
-src
-d
ql-eos-s3
-t
top
-v
counter_16bit.v
-p
chandalar.pcf
-P
PD64
-s
counter_16bit.sdc
pip uninstall
pip install -v fasm
