Install Symbiflow: ql_symbiflow: command not found
Posted: Wed Jan 27, 2021 1:33 am
I downloaded Symbiflow_v1.3.1.gz.run
The installation transcript has an error after several packages are downloaded and installed :
./conda_build_install_package.sh: line 25: curl: command not found
tar: arch.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
Collecting package metadata (current_repodata.json): done
Solving environment: done
The install finishes with :
Successfully built quicklogic-fasm fasm fasm-utils
Installing collected packages: Arpeggio, textx, fasm-utils, fasm, quicklogic-fasm
Successfully installed Arpeggio-1.10.1 fasm-0.0.2 fasm-utils-0.0.1 quicklogic-fasm-0.0.1 textx-2.3.0
I then execute the following :
gjones@geoff-VB-Ubuntu:~/Downloads$ export PATH="$INSTALL_DIR/quicklogic-arch-defs/bin:$INSTALL_DIR/quicklogic-arch-defs/bin/python:$PATH"
gjones@geoff-VB-Ubuntu:~/Downloads$ source "$INSTALL_DIR/conda/etc/profile.d/conda.sh"
gjones@geoff-VB-Ubuntu:~/Downloads$ conda activate
(base) gjones@geoff-VB-Ubuntu:~/Downloads$ ql_symbiflow -h
Do I neeed to install some other packages before running the install?
I'm running Ubuntu 20.04 LTS in VirtualBox-6.1.18-142142-Win
