Install Symbiflow: ql_symbiflow: command not found
gjones
I downloaded Symbiflow_v1.3.1.gz.run
The installation transcript has an error after several packages are downloaded and installed :
./conda_build_install_package.sh: line 25: curl: command not found
tar: arch.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
Collecting package metadata (current_repodata.json): done
Solving environment: done
The install finishes with :
Successfully built quicklogic-fasm fasm fasm-utils
Installing collected packages: Arpeggio, textx, fasm-utils, fasm, quicklogic-fasm
Successfully installed Arpeggio-1.10.1 fasm-0.0.2 fasm-utils-0.0.1 quicklogic-fasm-0.0.1 textx-2.3.0
I then execute the following :
gjones@geoff-VB-Ubuntu:~/Downloads$ export PATH="$INSTALL_DIR/quicklogic-arch-defs/bin:$INSTALL_DIR/quicklogic-arch-defs/bin/python:$PATH"
gjones@geoff-VB-Ubuntu:~/Downloads$ source "$INSTALL_DIR/conda/etc/profile.d/conda.sh"
gjones@geoff-VB-Ubuntu:~/Downloads$ conda activate
(base) gjones@geoff-VB-Ubuntu:~/Downloads$ ql_symbiflow -h
Do I neeed to install some other packages before running the install?
I'm running Ubuntu 20.04 LTS in VirtualBox-6.1.18-142142-Win
kishango
curl package is missing in your system.
Install it and run the process again.
sudo apt install curl
gjones
Thanks. That worked.
My Unix skill are a bit rusty.
jmoore
I might suggest using the envsetup.sh shell script found at the root of qorc-sdk.
source envsetup.sh
This will install the symbiflow/conda environments to a folder within qorc-sdk, as well as download the recommended compiler and set the toolchain path for it. Then, every time you wish to build, you can first source the setup script, and have everything ready to go.
