rsmb logs
Microsoft Windows [Version 10.0.18362.1016]
(c) 2019 Microsoft Corporation. All rights reserved.
W:\qorc\v1.1.0\qorc-sdk-1.1.0\Tools\rsmb>rsmb.exe .\rsmb_config.txt
20200911 145530.661 CWNAN9999I Really Small Message Broker
20200911 145530.661 CWNAN9998I Part of Project Mosquitto in Eclipse
http://projects.eclipse.org/projects/te ... .mosquitto)
20200911 145530.661 CWNAN0049I Configuration file name is .\rsmb_config.txt
20200911 145530.671 CWNAN0053I Version 1.3.0.2, Nov 19 2019 11:18:32
20200911 145530.671 CWNAN0054I Features included: bridge MQTTS
20200911 145530.672 CWNAN9993I Authors: Ian Craggs (
icraggs@uk.ibm.com), Nicholas O'Leary
20200911 145530.684 CWNAN0014I MQTT protocol starting, listening on port 1883
20200911 145530.685 CWNAN0300I MQTT-S protocol starting, listening on port 1885
20200911 145616.359 356 127.0.0.1:57089 <- MQTT-S CONNECT cleansession: 1
20200911 145616.366 356 127.0.0.1:57089 QL_S3 -> MQTT-S WILLTOPICREQ (0)
20200911 145616.366 CWNAN0000I Client connected to udp port 1885 from QL_S3 (127.0.0.1:57089)
20200911 145616.369 356 127.0.0.1:57089 QL_S3 <- MQTT-S CONNECT cleansession: 1
20200911 145616.372 356 127.0.0.1:57089 QL_S3 -> MQTT-S WILLTOPICREQ (0)
20200911 145616.372 CWNAN0000I Client connected to udp port 1885 from QL_S3 (127.0.0.1:57089)
20200911 145616.374 356 127.0.0.1:57089 QL_S3 <- MQTT-S CONNECT cleansession: 1
20200911 145616.375 356 127.0.0.1:57089 QL_S3 -> MQTT-S WILLTOPICREQ (0)
20200911 145616.375 CWNAN0000I Client connected to udp port 1885 from QL_S3 (127.0.0.1:57089)
20200911 145616.377 356 127.0.0.1:57089 QL_S3 <- MQTT-S CONNECT cleansession: 1
20200911 145616.377 356 127.0.0.1:57089 QL_S3 -> MQTT-S WILLTOPICREQ (0)
20200911 145616.378 CWNAN0000I Client connected to udp port 1885 from QL_S3 (127.0.0.1:57089)
20200911 145616.400 356 127.0.0.1:57089 QL_S3 <- MQTT-S WILLTOPIC qos: 1 retained: 1: topicname sensiml/sy
20200911 145616.400 356 127.0.0.1:57089 QL_S3 -> MQTT-S WILLMSGREQ (0)
20200911 145616.410 356 127.0.0.1:57089 QL_S3 <- MQTT-S WILLTOPIC qos: 1 retained: 1: topicname sensiml/sy
20200911 145616.420 356 127.0.0.1:57089 QL_S3 <- MQTT-S WILLTOPIC qos: 1 retained: 1: topicname sensiml/sy
20200911 145616.430 356 127.0.0.1:57089 QL_S3 <- MQTT-S WILLTOPIC qos: 1 retained: 1: topicname sensiml/sy
20200911 145616.440 356 127.0.0.1:57089 QL_S3 <- MQTT-S WILLMSG msg: offline
20200911 145616.440 1970322128 127.0.0.1:57089 QL_S3 -> MQTT-S CONNACK returncode 0 (0)
20200911 145616.474 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 1 topicid: 0 topicname: sensiml/sy
20200911 145616.474 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 1 topicid: 1 returncode: 0 (0)
20200911 145616.478 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 2 qos: 1 topicIdType 0
20200911 145616.527 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 2 topicid: 2 returncode: 0 (0)
20200911 145616.531 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 3 qos: 1 topicIdType 0
20200911 145616.588 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 3 topicid: 3 returncode: 0 (0)
20200911 145616.650 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 4 topicid: 0 topicname: sensiml/sy
20200911 145616.650 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 4 topicid: 4 returncode: 0 (0)
20200911 145616.696 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 5 qos: 1 topicIdType 0
20200911 145616.696 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 5 topicid: 5 returncode: 0 (0)
20200911 145616.762 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 6 topicid: 0 topicname: sensiml/sy
20200911 145616.762 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 6 topicid: 6 returncode: 0 (0)
20200911 145616.811 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 7 qos: 1 topicIdType 0
20200911 145616.812 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 7 topicid: 7 returncode: 0 (0)
20200911 145616.865 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 8 qos: 1 topicIdType 0
20200911 145616.865 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 8 topicid: 8 returncode: 0 (0)
20200911 145616.919 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 9 topicid: 0 topicname: sensiml/sy
20200911 145616.919 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 9 topicid: 9 returncode: 0 (0)
20200911 145616.961 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 10 qos: 1 topicIdType 0
20200911 145616.961 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 10 topicid: 10 returncode: 0 (0)
20200911 145617.012 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 11 topicid: 0 topicname: sensiml/sy
20200911 145617.012 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 11 topicid: 11 returncode: 0 (0)
20200911 145617.054 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 12 qos: 1 topicIdType 0
20200911 145617.055 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 12 topicid: 12 returncode: 0 (0)
20200911 145617.109 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 13 qos: 1 topicIdType 0
20200911 145617.109 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 13 topicid: 13 returncode: 0 (0)
20200911 145617.160 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 14 topicid: 0 topicname: sensiml/li
20200911 145617.160 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 14 topicid: 14 returncode: 0 (0)
20200911 145617.164 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 15 qos: 1 topicIdType 0
20200911 145617.205 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 15 topicid: 15 returncode: 0 (0)
20200911 145617.210 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 16 topicid: 0 topicname: sensiml/li
20200911 145617.269 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 16 topicid: 16 returncode: 0 (0)
20200911 145617.319 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 17 qos: 1 topicIdType 0
20200911 145617.319 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 17 topicid: 17 returncode: 0 (0)
20200911 145617.382 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 18 topicid: 0 topicname: sensiml/li
20200911 145617.382 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 18 topicid: 18 returncode: 0 (0)
20200911 145617.430 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 19 qos: 1 topicIdType 0
20200911 145617.431 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 19 topicid: 19 returncode: 0 (0)
20200911 145617.484 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 20 qos: 1 topicIdType 0
20200911 145617.484 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 20 topicid: 20 returncode: 0 (0)
20200911 145617.537 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 21 topicid: 0 topicname: sensiml/re
20200911 145617.537 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 21 topicid: 21 returncode: 0 (0)
20200911 145617.542 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 22 qos: 1 topicIdType 0
20200911 145617.592 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 22 topicid: 22 returncode: 0 (0)
20200911 145617.597 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 23 qos: 1 topicIdType 0
20200911 145617.657 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 23 topicid: 23 returncode: 0 (0)
20200911 145617.720 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 24 topicid: 0 topicname: sensiml/re
20200911 145617.720 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 24 topicid: 24 returncode: 0 (0)
20200911 145617.770 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 25 qos: 1 topicIdType 0
20200911 145617.770 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 25 topicid: 25 returncode: 0 (0)
20200911 145617.824 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 26 qos: 1 topicIdType 0
20200911 145617.824 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 26 topicid: 26 returncode: 0 (0)
20200911 145617.890 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 27 qos: 1 topicIdType 0
20200911 145617.890 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 27 topicid: 27 returncode: 0 (0)
20200911 145617.954 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 28 topicid: 0 topicname: sensiml/st
20200911 145617.954 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 28 topicid: 28 returncode: 0 (0)
20200911 145618.003 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 29 qos: 1 topicIdType 0
20200911 145618.003 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 29 topicid: 29 returncode: 0 (0)
20200911 145618.066 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 30 topicid: 0 topicname: sensiml/st
20200911 145618.066 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 30 topicid: 30 returncode: 0 (0)
20200911 145618.070 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 31 qos: 1 topicIdType 0
20200911 145618.111 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 31 topicid: 31 returncode: 0 (0)
20200911 145618.115 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 32 qos: 1 topicIdType 0
20200911 145618.174 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 32 topicid: 32 returncode: 0 (0)
20200911 145618.178 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 33 qos: 1 topicIdType 0
20200911 145618.236 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 33 topicid: 33 returncode: 0 (0)
20200911 145618.241 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 34 topicid: 0 topicname: sensiml/st
20200911 145618.301 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 34 topicid: 34 returncode: 0 (0)
20200911 145618.350 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 35 qos: 1 topicIdType 0
20200911 145618.350 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 35 topicid: 35 returncode: 0 (0)
20200911 145618.404 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 36 qos: 1 topicIdType 0
20200911 145618.404 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 36 topicid: 36 returncode: 0 (0)
20200911 145618.471 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 37 qos: 1 topicIdType 0
20200911 145618.471 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 37 topicid: 37 returncode: 0 (0)
20200911 145618.531 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 38 qos: 1 topicIdType 0
20200911 145618.531 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 38 topicid: 38 returncode: 0 (0)
20200911 145618.584 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 39 qos: 1 topicIdType 0
20200911 145618.584 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 39 topicid: 39 returncode: 0 (0)
20200911 145618.646 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 40 qos: 1 topicIdType 0
20200911 145618.646 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 40 topicid: 40 returncode: 0 (0)
20200911 145618.700 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 41 qos: 1 topicIdType 0
20200911 145618.700 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 41 topicid: 41 returncode: 0 (0)
20200911 145618.754 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 42 qos: 1 topicIdType 0
20200911 145618.755 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 42 topicid: 42 returncode: 0 (0)
20200911 145618.817 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 43 topicid: 0 topicname: sensiml/se
20200911 145618.817 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 43 topicid: 43 returncode: 0 (0)
20200911 145618.822 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 44 qos: 1 topicIdType 0
20200911 145618.862 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 44 topicid: 44 returncode: 0 (0)
20200911 145618.928 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 45 qos: 1 topicIdType 0
20200911 145618.928 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 45 topicid: 45 returncode: 0 (0)
20200911 145618.990 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 46 qos: 1 topicIdType 0
20200911 145618.990 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 46 topicid: 46 returncode: 0 (0)
20200911 145619.059 356 127.0.0.1:57089 QL_S3 <- MQTT-S SUBSCRIBE msgid: 47 qos: 1 topicIdType 0
20200911 145619.059 356 127.0.0.1:57089 QL_S3 -> MQTT-S SUBACK msgid: 47 topicid: 47 returncode: 0 (0)
20200911 145619.118 356 127.0.0.1:57089 QL_S3 <- MQTT-S REGISTER msgid: 48 topicid: 0 topicname: sensiml/sy
20200911 145619.118 356 127.0.0.1:57089 QL_S3 -> MQTT-S REGACK msgid: 48 topicid: 48 returncode: 0 (0)
20200911 145619.169 356 127.0.0.1:57089 QL_S3 <- MQTT-S PUBLISH msgid: 49 qos: 1 retained: 1
20200911 145619.169 1970322128 127.0.0.1:57089 QL_S3 -> MQTT-S PUBACK msgid: 49 (0)
20200911 145619.222 356 127.0.0.1:57089 QL_S3 <- MQTT-S PUBLISH msgid: 50 qos: 1 retained: 0
20200911 145619.222 1970322128 127.0.0.1:57089 QL_S3 -> MQTT-S PUBACK msgid: 50 (0)
20200911 145721.769 356 127.0.0.1:57089 QL_S3 -> MQTT-S PINGRESP (0)
20200911 145824.253 356 127.0.0.1:57089 QL_S3 -> MQTT-S PINGRESP (0)
20200911 145949.722 360 SensiML-Host <- CONNECT
20200911 145949.723 CWNAN0033I Connection attempt to listener 1883 received from client SensiML-Host on address 127.0.0.1:55367
20200911 145949.725 360 SensiML-Host -> CONNACK rc: 0 (0)
20200911 145949.728 360 SensiML-Host <- SUBSCRIBE msgid: 1
20200911 145949.729 360 SensiML-Host -> SUBACK msgid: 1 (0)
20200911 145949.729 360 SensiML-Host -> PUBLISH msgid: 1 qos: 1 retained: 1 (0)
20200911 145949.732 360 SensiML-Host <- PUBLISH msgid: 2 qos: 1 retained: 0
20200911 145949.733 360 SensiML-Host -> PUBACK msgid: 2 (0)
20200911 145949.733 356 127.0.0.1:57089 QL_S3 -> MQTT-S PUBLISH msgid: 1 qos: 1 retained: 0 (0)
20200911 145949.742 360 SensiML-Host <- PUBACK msgid: 1
20200911 145949.935 360 SensiML-Host <- PUBLISH msgid: 3 qos: 1 retained: 0
20200911 145949.936 360 SensiML-Host -> PUBACK msgid: 3 (0)
20200911 150049.975 360 SensiML-Host <- PINGREQ
20200911 150049.975 360 SensiML-Host -> PINGRESP (0)
20200911 150150.008 360 SensiML-Host <- PINGREQ
20200911 150150.008 360 SensiML-Host -> PINGRESP (0)
20200911 150250.048 360 SensiML-Host <- PINGREQ
20200911 150250.048 360 SensiML-Host -> PINGRESP (0)
20200911 150350.092 360 SensiML-Host <- PINGREQ
20200911 150350.092 360 SensiML-Host -> PINGRESP (0)
