Connecting sensors to QuickFeather
Posted: Wed Oct 12, 2022 2:07 pm
by Robert
Customer Question: How do you interface the Quick Feather Dev board with other sensors ? or is that the only available input (from the external world) is the UART ?
Answer>> Typically most sensors have I2C or SPI interfaces. The easiest interface to connect to one of the two I2C interfaces on the EOS S3 QuickFeather board.
A video showing an example is available at available at https://sensiml.com/resources/tutorials/
Then search for the "Connecting new I2C Sensors to the QuickFeather Dev Board & Capturing Data in SensiML"
The QORC project is available https://github.com/QuickLogic-Corp/qorc ... ssi_ai_app
If you have questions on how to build the Eclipse Project then a good video is https://www.youtube.com/watch?v=tsgGCFGhn8Q
Details on the QuickFeather board can be found at https://www.youtube.com/watch?v=YF2DLafwbTg and https://github.com/QuickLogic-Corp/quic ... master/doc
Good luck and I hope this helps.
