I have the same problem. On Win10, it does not find the driver and displays error code 10. Because of this error, I cannot follow the example from your video
https://www.youtube.com/watch?v=OW4wNNL ... ackster.io.
When trying to run the command from the example: python tinyfpga-programmer-gui.py --port COM4 --m4 quickfeather-simple-stream-data-collection.bin --mode m4
Outputs:
CLI mode
ports = ['COM4 (QuickFeather)'] 1
Using port COM4 (QuickFeather)
File "D: \ QuickLogic \ TinyFPGA-Programmer-Application \ tinyfpga-programmer-gui.py", line 622, in <module>
adapter.program (m4appname, progress, "Programming m4 application with", args.checkrev, args.update)
File "D: \ QuickLogic \ TinyFPGA-Programmer-Application \ tinyfpga-programmer-gui.py", line 144, in program
with serial.Serial (self.port [0], 115200, timeout = 60, writeTimeout = 60) as ser:
File "C: \ Users \ maxpower \ AppData \ Local \ Programs \ Python \ Python39 \ lib \ site-packages \ serial \ serialwin32.py", line 33, in _
_init__
super (Serial, self) .__ init __ (* args, ** kwargs)
File "C: \ Users \ maxpower \ AppData \ Local \ Programs \ Python \ Python39 \ lib \ site-packages \ serial \ serialutil.py", line 244, in _
_init__
self.open ()
File "C: \ Users \ maxpower \ AppData \ Local \ Programs \ Python \ Python39 \ lib \ site-packages \ serial \ serialwin32.py", line 64, in o
pen
raise SerialException ("could not open port {! r}: {! r}". format (self.portstr, ctypes.WinError ()))
serial.serialutil.SerialException: could not open port 'COM4': FileNotFoundError (2, 'The specified file cannot be found.',
None, 2)
Is there a solution to this problem?
