I am new to the QORC SDK and have just started playing around with the TInyFPGA Application
However, I am unable to understand why I always get an error regarding not finding the binaries at the specified location even when I am very sure that I have used the right location
This is the terminal output:
moinak@moinak-VirtualBox:~/TinyFPGA-Programmer-Application$ sudo python3 tinyfpga-programmer-gui.py --port=COM15 --bootloader qf_bootloader.bin[sudo] password for moinak:
usage: tinyfpga-programmer-gui.py [-h] [--mode [fpga-m4]] [--m4app app.bin]
[--appfpga appfpga.bin]
[--bootloader boot.bin]
[--bootfpga fpga.bin] [--reset]
[--port /dev/ttySx] [--crc] [--checkrev]
[--update] [--mfgpkg qf_mfgpkg/]
tinyfpga-programmer-gui.py: error: argument --bootloader/--bl: can't open 'qf_bootloader.bin': [Errno 2] No such file or directory: 'qf_bootloader.bin'
moinak@moinak-VirtualBox:~/TinyFPGA-Programmer-Application$ sudo python3 tinyfpga-programmer-gui.py --port=COM15 --bootfpga qf_bootfpga.bin
tinyfpga-programmer-gui.py: error: argument --bootfpga: can't open 'qf_bootfpga.bin': [Errno 2] No such file or directory: 'qf_bootfpga.bin'
If you have any random clue regarding why this is happening please let me know urgently
Thanking you,
Moinak
TinyFPGAProgammer Flash issue on Quickfeather
Hi @moinakg2, Please verify that qf_bootloader.bin file is located in the directory where the command is being invoked. To verify issue the command
Typically bootloader is not required to be programmed. To program an application binary use the --m4app option.
$ ls qf_bootloader.bin
