Not showing Knowledge Pack Results on Serial.
salmanfarisvp
Hi, I'm using QuickFeather microphone data to make the model, data aquastion and modelling done by following the tutorial, but after flashing the .bin Knowledge Pack , with 460800 buad mentioned in the doc https://sensiml.com/documentation/firm ... le-stream . The classification results is not printing , Any Idea?
Screenshot 2021-02-25 121551.png (6.95 KiB) Viewed 47024 times
jmoore
Any chance you could provide us with the knowledgepack UUID, and which platform was chosen for build?
salmanfarisvp
Sure, Here you can get the file.
salmanfarisvp
@jmoore any fix for the issue?
jmoore
Would you be able to provide the library build? Not much I can do with a binary for debugging.
Is this running on battery? I'd like to recreate your use case as closely as I can.
Thanks!
salmanfarisvp
How Can I provide the libaray build? Please share more details on that!
jmoore
When you are downloading from app.sensiml.com - select library in output format:
if this is not available, let us know, as Community edition should still be able to get this format.
juanyi
Hello, I was having the same issue initially. But after some investigation and trial/error, I think I found an answer to it. We need to select the debug option when we download the knowledge pack. This works for me.
I have a somewhat strange finding though, when the project is using accelerometer, I don't need to tick this debug option to have the serial output. This only needed when I use the audio sensor.
