As titled, how to change hardware uart to serial port for data capture?
BTW, no idea why qorc-sdk v1.10.0 is not working with DCL? I did use a USB to TTL serial adapter and connected as instruction. It works with pre-built firmware qf-ss-imu-data-collection-uart-100hz.bin.
I also would like to know why has two virtual com ports in device manager while QF board is with qf-ss-imu-data-collection-uart-100hz.bin but only one virtual com port from usb serial adapter while QF board is with data capture firmware built from qorc-sdk v1.10.0
built with Eclipse 2021-12
C:\GnuWin32\bin
C:\Program Files (x86)\GNU Tools ARM Embedded\8 2019-q3-update\bin
how to change the setting in QORC-sdk to use serial port instead of hardware uart for data capture?
murthy.vedula
To use the USB-Serial port for data capture change the settings in Fw_global_config.h file in qf_apps/qf_ssi_ai_app/inc folder as below:
#define DEBUG_UART (UART_ID_HW) // Set the output of debug messages
#define UART_ID_APP (UART_ID_USBSERIAL) // Set the output for application messages
Hi Murthy,
Thanks for the reply to how to use usb serial port for data capture.
For the question about why qorc-sdk v1.10 is not working with DCL, I did a comparison with v1.9 and made a modifications as attached file.
After modifications, it works with DCL but no idea why ldo is the cause of this problem?
- Attachments
- ldo_init.jpg (107.66 KiB) Viewed 79996 times
Many thanks for the solution.murthy.vedula wrote: ↑Fri Feb 04, 2022 6:51 pm To use the USB-Serial port for data capture change the settings in Fw_global_config.h file in qf_apps/qf_ssi_ai_app/inc folder as below:
#define DEBUG_UART (UART_ID_HW) // Set the output of debug messages #define UART_ID_APP (UART_ID_USBSERIAL) // Set the output for application messages
