Looking for documentation about eFPGA macrocells (EOS-S3)
Martoni
When I launch synthesis with QORC commands I get log files that give occupancy statistics in file «/opt/qorc-sdk/qf_apps/qf_helloworldhw/fpga/rtl/build/helloworldfpga_synth.log» (for helloworld app) :
13. Printing statistics.
=== helloworldfpga ===
   Number of wires:               1055
   Number of wire bits:           1055
   Number of public wires:        1055
   Number of public wire bits:    1055
   Number of memories:               0
   Number of memory bits:            0
   Number of processes:              0
   Number of cells:                119
     ASSP                            1
     BIDIR_CELL                      3
     C_FRAG                         13
     F_FRAG                          1
     Q_FRAG                         44
     T_FRAG                         57
route.log give more cells :
Pb types usage...
  PB-SYN_GND        : 1
   GND              : 1
  PB-BIDIR          : 3
   BIDIR            : 3
    OUTPUT          : 3
     bidir          : 3
     outpad         : 3
  PB-ASSP           : 1
   ASSP             : 1
  PB-LOGIC          : 56
   LOGIC            : 56
    FRAGS           : 56
     c_frag_modes   : 56
      SINGLE        : 13
       c_frag       : 13
      SPLIT         : 43
       b_frag       : 43
       t_frag       : 14
     f_frag         : 1
     q_frag_modes   : 44
      INT           : 43
       q_frag       : 43
      EXT           : 1
       q_frag       : 1
  PB-SYN_VCC        : 1
   VCC              : 1
Device Utilization: 0.05 (target 1.00)
	Physical Tile TL-LOGIC:
	Block Utilization: 0.06 Logical Block: PB-LOGIC
	Physical Tile TL-RAM:
	Block Utilization: 0.00 Logical Block: PB-RAM
	Physical Tile TL-MULT:
	Block Utilization: 0.00 Logical Block: PB-MULT
	Physical Tile TL-BIDIR:
	Block Utilization: 0.09 Logical Block: PB-BIDIR
	Physical Tile TL-CLOCK:
	Block Utilization: 0.00 Logical Block: PB-CLOCK
	Physical Tile TL-SDIOMUX:
	Block Utilization: 0.00 Logical Block: PB-SDIOMUX
	Physical Tile TL-GMUX:
	Block Utilization: 0.00 Logical Block: PB-GMUX
	Physical Tile TL-ASSP:
	Block Utilization: 1.00 Logical Block: PB-ASSP
	Physical Tile TL-SYN_VCC:
	Block Utilization: 1.00 Logical Block: PB-SYN_VCC
	Physical Tile TL-SYN_GND:
	Block Utilization: 1.00 Logical Block: PB-SYN_GND
Where can I found documentation about this cells ?
Martoni
I can't find eFPGA mapping of macrocells in this datasheet or this.
The reference manual has a section of the FPGA. If you want to understand how to interface the FPGA I would suggest the following additional resources
https://github.com/coolbreeze413/qorc-onion-apps
This has a range of basic examples of how to interface the EOS device with your FPGA design.
A video tutorial is also available at https://www.quicklogic.com/products/soc ... ontroller/
Then select the SymbiFlow with QuickFeather – A simple FPGA Programming Example video
Additional documentation is also available at https://quicklogic-quicklogic-fpga-tool ... ecoun.html
I will update with the naming of the Logic cell fragmentation.
The FPGA Logic Cell in EOS S3 can be fragmented into four pieces
[img][
PP3 .png (23.93 KiB) Viewed 3900 times
/img]
The frag F is also referred to as b.
