Sample rates not matching
Posted: Tue Feb 02, 2021 4:17 pm
by GabrielSt
Hi, I am having trouble getting data from the on-board microphone in the DCL software. It seems that the sample rates do not match with the firmware one. I took the driver from "https://github.com/QuickLogic-Corp/qorc ... import.ssf". Also, this is the log file:
"[92] 6:03 PM: Success - 'Sensor 1' configuration created
[93] 6:04 PM: Error - The sample rate configured in your device firmware does not match your sensor configuration. Setup a new sensor configuration with the matching sample rate or reconfigure your data collection firmware
[94] 6:04 PM: Error - QuickFeather SimpleStream - COM5 data collection firmware sent sample rate 100. Sensor configuration sample rate is 16000"
What should I do? Any help is welcome!
Re: Sample rates not matching
Posted: Tue Feb 02, 2021 7:44 pm
by jmoore
You will need to rebuild the firmware to collect Audio - qf_apps/qf_ssi_ai_app/inc/Fw_global_config.h lines 73/74:
#define SSI_SENSOR_SELECT_AUDIO (0) // 1 => Select Audio data for live-streaming or recognition modes Change this to a 1
#define SSI_SENSOR_SELECT_SSSS (1) // 1 => Select SSSS sensor data for live-streaming of recognition modes Change this to a 0
From there, you can build and flash. the Quickfeather should then be sending audio configuration, and then audio data, instead of IMU.
Note - you may also want to update to Data Capture Lab 2020.10.4 (releasing today, 2/2/2021), as it adds audio as a natively supported source rather than needing to import with SSF.
Posted: Wed Feb 03, 2021 1:09 pm
by juanyi
jmoore wrote: ↑Tue Feb 02, 2021 7:44 pm You will need to rebuild the firmware to collect Audio - qf_apps/qf_ssi_ai_app/inc/Fw_global_config.h lines 73/74:
This works. Thanks for the post. After changing according to the above, there were compilation error initially, that is because the GCC_project already loaded with files from previous compilation, so for those who have same issue, remember to 'make clean' first then 'make' again.
