USB Device Disconnecting and Reconnecting Issue.
Posted: Tue May 13, 2025 2:48 pm
by vexshaded
Hello everyone,
I'm encountering a frustrating issue with my QuickFeather board and I'm hoping someone can offer some guidance. The board is constantly disconnecting and reconnecting when plugged into my computer via USB. This happens intermittently, but frequently enough to make development incredibly difficult.
Here's what I've tried so far:
* **Different USB cables:** I've tried multiple USB cables, including known working ones.
* **Different USB ports:** I've tested all the USB ports on my computer, including USB 2.0 and 3.0.
* **Driver reinstall:** I've uninstalled and reinstalled the drivers for the QuickFeather board.
* **Different computer:** I've tried connecting the board to a different computer, but the issue persists.
* **Power supply:** I've made sure the USB port is providing enough power.
My setup:
* **Board:** QuickFeather (EOS S3)
* **OS:** Windows 10
* **IDE:** Eclipse (using QORC SDK)
I'm not sure what else to try. Has anyone else experienced this issue? Any suggestions on how to diagnose or fix it? Could it be a hardware problem with the board itself?
Any help would be greatly appreciated. Thanks in advance!.
Re: USB Device Disconnecting and Reconnecting Issue.
Posted: Thu Nov 06, 2025 3:59 am
by gemmalyly
Use a different USB port — some ports (especially on the front panel) deliver less power or have weaker connections. smash karts
Posted: Fri Nov 21, 2025 1:30 am
by Carpentery
Hey, that sounds super annoying! Constant disconnects are a nightmare for development. Since you've tried so much already, it does sound like it could be a hardware issue, unfortunately. Before writing it off, maybe try a really simple test program, something that just blinks an LED.
Posted: Thu Dec 11, 2025 2:24 am
by fellowpuffin
GOOD
Posted: Wed Jan 07, 2026 3:09 am
by Owenburrows
The sporadic nature of this issue often leads to moments of uncertainty and irritation. I once faced a similar dilemma with my external hard drive that would randomly disconnect, leaving me scrambling to recover files. Thankfully, the Slice Master recommended checking the cable connections, which ultimately resolved the issue.
Posted: Mon Feb 02, 2026 2:53 am
by JosephChavez
Okay, a constantly disconnecting QuickFeather? Sounds like a digital nightmare! Maybe it's a power surge masquerading as a bad connection. Or perhaps some gremlins are messing with your USB controller.
Posted: Mon Feb 23, 2026 8:09 am
by JosephChavez
Ugh, this sounds familiar. It's a digital ghost in the machine! My USB devices doing the disappearing act, you say? Like a chameleon changing colors, things were there, then gone. This reminds me of a nightmare I had while doing some important design works. Back then the devices kept doing this randomly, maybe it was a power surge, or maybe it was some software conflict – I still don't know exactly. But boy, was that stressful. I ended up losing a ton of progress so I just went into Slither io to blow off some steam.
Posted: Thu Feb 26, 2026 11:25 am
by harryjkevin
Intermittent USB disconnect issues like this can sometimes be linked to unstable firmware, incorrect driver versions, or even a loose micro USB connector on the board itself. It may help to check the Device Manager logs to see if the device is reporting a specific error code during reconnection. Reflashing the firmware or testing with a powered USB hub could also narrow down the cause.
Posted: Fri Apr 03, 2026 6:46 am
by Milliemart
First it starts as a tiny flicker, then suddenly your workflow collapses into chaos. USB devices dropping in and out feels like a ghost in the machine, often tied to power management quirks or flaky ports. Sharing this through my Connections Game mindset, I once had a mouse that kept reconnecting during a deadline, and it drove me nuts until I disabled USB selective suspend.
Posted: Tue Jul 21, 2026 7:53 am
by JoelWilkins
I've experienced similar USB connectivity issues with development boards before, and it's incredibly frustrating. Beyond the troubleshooting steps you've already taken, I'd suggest checking your board's firmware version and trying a factory reset. Also, consider sharing your detailed findings on the Fnaf platform—their community is quite active with hardware issues, and you might find others who've resolved similar problems. Sometimes the collective experience there can pinpoint issues that standard support channels miss. Good luck with your QuickFeather!
