EOS S3 Interrupt Numbers
Posted: Thu Jul 02, 2020 6:45 am
by btashton
Re: EOS S3 Interrupt Numbers
Posted: Wed Jul 08, 2020 1:07 pm
by gmartin
typedef enum
/****** Cortex-M4 Processor Exceptions Numbers ****************************************************************/
NonMaskableInt_IRQn = -14, /*!< 2 Non Maskable Interrupt */
MemoryManagement_IRQn = -12, /*!< 4 Cortex-M4 Memory Management Interrupt */
BusFault_IRQn = -11, /*!< 5 Cortex-M4 Bus Fault Interrupt */
UsageFault_IRQn = -10, /*!< 6 Cortex-M4 Usage Fault Interrupt */
SVCall_IRQn = -5, /*!< 11 Cortex-M4 SV Call Interrupt */
DebugMonitor_IRQn = -4, /*!< 12 Cortex-M4 Debug Monitor Interrupt */
PendSV_IRQn = -2, /*!< 14 Cortex-M4 Pend SV Interrupt */
SysTick_IRQn = -1, /*!< 15 Cortex-M4 System Tick Interrupt */
/****** Specific Interrupt Numbers **********************************************************************/
SwInt2_IRQn = 0,
SwInt1_IRQn = 1,
Reserved1_IRQn = 2,
Ffe0Msg_IRQn = 3,
FbMsg_IRQn = 4,
Gpio_IRQn = 5,
SramSleep_IRQn = 6,
Uart_IRQn = 7,
Timer_IRQn = 8,
CpuWdtInt_IRQn = 9,
CpuWdtRst_IRQn = 10,
BusTimeout_IRQn = 11,
Fpu_IRQn = 12,
Pkfb_IRQn = 13,
Reserved_I2s_IRQn = 14,
Reserved_Audio_IRQn = 15,
SpiMs_IRQn = 16,
CfgDma_IRQn = 17,
PmuTimer_IRQn = 18,
AdcDone_IRQn = 19,
RtcAlarm_IRQn = 20,
ResetInt_IRQn = 21,
Ffe0_IRQn = 22,
FfeWdt_IRQn = 23,
ApBoot_IRQn = 24,
Ldo30_pg_IRQn = 25,
Ldo50_pg_IRQn = 26,
Sram_to_IRQn = 27,
Lpsd_IRQn = 28,
Dmic_IRQn = 29,
Reserved2_IRQn = 30,
Sdma_Done1_IRQn = 31,
Sdma_Done2_IRQn = 32,
Sdma_Done3_IRQn = 33,
Sdma_Done4_IRQn = 34,
Sdma_Done5_IRQn = 35,
Sdma_Done6_IRQn = 36,
Sdma_Done7_IRQn = 37,
Sdma_Done8_IRQn = 38,
Sdma_Done9_IRQn = 39,
Sdma_Done10_IRQn = 40,
Sdma_Done11_IRQn = 41,
Ap_Pdm_Clock_On_IRQn = 42,
Ap_Pdm_Clock_Off_IRQn = 43,
Dmac0_Block_Done_IRQn = 44,
Dmac0_Buffer_Done_IRQn = 45,
Dmac1_Block_Done_IRQn = 46,
Dmac1_Buffer_Done_IRQn = 47,
Sdma_Done0_IRQn = 48,
Sdma_Err_IRQn = 49,
I2SSlv_M4_IRQn = 50,
Lpsd_Voice_Off_IRQn = 51,
Dmic_Voice_Off_IRQn = 52
} IRQn_Type;
Posted: Wed Jul 08, 2020 4:31 pm
by btashton
Posted: Wed Jul 08, 2020 5:22 pm
by gmartin
Looking to get the information you requested. We will be updating our TRM as appropriate, but will reply separately with the information you requested.
Posted: Wed Jul 08, 2020 11:58 pm
by gmartin
Posted: Thu Jul 09, 2020 5:28 am
by btashton
Really appreciate it, this is the information I was looking for.
Posted: Fri Apr 23, 2021 4:58 am
by tejar37
Well, I totally agree with you. this is something amazing. I highly admire. Love it. This is something amazing and extra ordinary
Posted: Tue Nov 02, 2021 11:05 am
by Tratc1956
Thanks @gmartin for the answers. I am looking forward to more answers about this one as I have the same problem.
atlanta mobile detailing
Posted: Mon Jun 27, 2022 10:42 am
by tejar37
This guide provides users with functional descriptions
, configuration options for the QuickLogic Thing Plus EOS S3. It also serves as a “Getting Started".
Posted: Tue Oct 15, 2024 4:55 am
by Bradley Fields
I just joined the community looking for help and found someone with the same problem and the answer! Awesome. Your answer helped me a lot
getaway shootout
