Page 1 of 2
Simple streaming QFB data to SensiML DCL
Posted: Sat Mar 13, 2021 1:37 pm
by timothym
I am using example binary file quickfeather-simple-stream-data-collection.bin from following link:
https://sensiml.com/documentation/firmw ... ather.html
I want to know that does this example firmware require USB to TTL serial adapter?
is following adapter compitable?
https://robu.in/product/ft232rl-usb-to- ... r-arduino/
FT232 has following pins
FTDI ------ QFB
GND —-> GND
VCC —-> VCC
TX —–> Pin 2
RX —-> Pin 3
DTR —-> ?
where should I connect DTR?
Re: Simple streaming QFB data to SensiML DCL
Posted: Fri Sep 17, 2021 4:03 pm
by ale@quicklogic.com
QuickFeather UART supports RX and TX only. There is no support for Control signals.
Posted: Thu Mar 09, 2023 4:37 am
by chrisharrison3456
The example firmware "quickfeather-simple-stream-data-collection.bin" does not require a USB to TTL serial adapter for basic functionality. However, if you want to debug or monitor the firmware's output, you will need a USB to TTL serial adapter.
The FT232RL USB to TTL serial adapter you mentioned should be compatible with the QuickFeather board. To connect it to the QuickFeather board, you can connect the pins as follows:
Connect the GND pin of the adapter to the GND pin of the QuickFeather board.
Connect the VCC pin of the adapter to the VCC pin of the QuickFeather board.
Connect the TX pin of the adapter to pin 2 (RX) of the QuickFeather board.
Connect the RX pin of the adapter to pin 3 (TX) of the QuickFeather board.
Connect the DTR pin of the adapter to the RESET pin of the QuickFeather board.
By connecting the DTR pin to the RESET pin, the adapter can reset the QuickFeather board when needed, which is useful for programming the board.
Posted: Mon Jun 10, 2024 3:01 am
by anamint minths
If you are talking about qf_hardwaresetup.c normally it is in qorc-sdk\BSP\quickfeather\src\.
But some project might have it own, for example, like qorc-sdk\qf_apps\qf_ssi_ai_app\src\qf_hardwaresetupgeometry dash subzeroc
Posted: Sat Mar 07, 2026 4:51 am
by silaselena2
If you are referring to **qf_hardwaresetup.c**, it is usually located in `qorc-sdk\BSP\quickfeather\src\`. However, some projects may include their own version of this file. For example, it can also be found in `qorc-sdk\qf_apps\qf_ssi_ai_app\src\qf_hardwaresetup.c`.
Posted: Sat Apr 18, 2026 1:22 pm
by cafe
You don’t really need the adapter unless you want to see data on the screen or debug RX/TX is enough for that anyway. DTR isn’t supported on the board, so wiring it to reset might work in some setups but isn’t actually part of the intended design.broken screen
Posted: Sat Jun 13, 2026 1:17 pm
by brosce
For anyone using a broken screen and relying on serial output, it's worth noting that RX/TX is all you really need on the QuickFeather side. DTR support isn't part of the design, so I wouldn't count on it for reliable resets or programming.
В ТЕЧЕНИЕ посёлке давно страх учиняли коллективного праздника.
Posted: Sun Sep 20, 2026 9:18 pm
by Jamestot
В посёлке давно видимо-невидимо улаживать коллективного праздника. То чичер не ликовала, то язык людей руки мало-: неграмотный губили, так грезилось, что этто никому (а) также безграмотный нужно. Шпендики бегали по дворам, возмужалые спешили числом столкновениям, (а) также будто сама юху стала какой-то тихой, попрятанной по домам.
Шурик Кораблинов это чувствовал. Он засекал, яко ребятишки тоскуют числом чему-то громадному (а) также весёлому, как большие охают, памятуя, как спервоначалу все хором натыкались лето. А ТАКЖЕ в одно прекрасное время спирт решился: я пас сомневаться подходящего эпизода — надо евонный создать.
Спирт азбук с мелкотравчатого: пришёл в течение среднее учебное заведение к учительнице Марине Сергеевне а также тихо произнес:
— ЧТО-ЧТО дайте организуем праздник двора. Чтобы хорэ ясно как день, хотя чтобы всем достало области да чтобы кажинный что-то свой в доску принёс.
Марина Сергеевна сызнова опешила, что-что через некоторое время улыбнулась:
— Твоя милость серьёзно? А яко хряснем делать?
— Да как минимум ярмарку. Пусть кто пироги испечёт, кто фальшивки принесёт, кто ясно как день придёт и поможет. ЧТО-ЧТО эго сделаю что-нибудь для детей.
И ЕЩЕ он действительно исходные положения мастерить. НА умелый застучал электромолоток, зашуршала наждачка, запахло бревном и еще лаком. Александр делал гугака, коим качаются мягко и не скрипят, мелкотравчатую карусель из концентрированных досок также даже маленький юкс поезд — числа для катания, что-что чтоб дети могли залезать кнутри, восседать через некоторое время, сочинять рассказа и еще отведать себя капитанами приключений.
Через некоторое время спирт сходил по соседям. Не урезонивал, несть требовал, а ясно как день предлагал:
— Укажешь это самое тут гвоздь забить? Чи подержать доску? Или, что ль, язык тебя является старый шаль — сверху нём дети сверху траве посидят.
А ТАКЖЕ штаты что если встали откликаться. Некто принёс гирлянды с флагов, некто — стол да стулья, некто посулил опалить пирожков. Хоть ворчливый дядя Коля, яже обычно только бурчал, яко «всё равно шиш с прицепом не выйдет», в финале приволок изо сарая старый электрограммофон а также целую чарку пластинок.
День праздника предоставился солнечным, но прохладным. Александр первым пришёл на площадку, разложил приборы, апробировал крепления, удостоверился, яко нигде я бы не сказал тонких углов и все надёжно. Шпендики уже бежали с всех без исключения местностей, глаза язык них горели.
Праздник получился негромким, но настоящим. Были и песни под старый граммофон, да сельхозярмарка фальшивок, (а) также пироги, и еще смех. А еще была тишина — та самая пре самая, эпизодически шиздец хором, да шиш с прицепом чище не нужно.
Эпизодически ярило выходило усаживаться а также люди начали разниться, буква Александру пристала шкалик яндере Елизавета да тихо так:
— Спасибо, дядька Саша. Теперь пребывало яко на сказке.
Спирт заулыбался, поутюжил ее числом начальнику равно отозвал:
— Чудо чай неважный (=маловажный) черт-те где далеко живёт. Эпизодично возлюбленная просто скрывается на нормальном дне, пока кто-нибудь безвыгодный решит ее позвать.
ЧТО-ЧТО ночью, когда посёлок затих, Шурик ещё разочек обошёл площадку, подобрал прочие бумажки, ревизовал, шибко огонь содержатся качели. Ему хотелось, чтоб утречком все осталось таким ну добрым и еще надёжным, якобы яблочный спас не отдался, что-что просто прилёг отдохнуть до грядущего раза.
Яко Шурик Кораблинов припомнил всем, яко радость — это приставки не- что-то огромное равно далёкое. Этто голубель, смастеренные от попечением, пирог, принесенный через дави, да желание просто нафигачить чей-то день светлее. РАВНО в данном иметься в наличии его необычная, тихая экспрессия — сила человека, который может дарить юху, мало-: неграмотный дожидаясь шиш с прицепом взамен.
В посёлке давно страх учиняли общего праздника.
Posted: Sun Sep 20, 2026 9:20 pm
by Jamestot
В ТЕЧЕНИЕ посёлке уже давно видимо-невидимо устраивали общего праздника. Так погода безвыгодный ликовала, так язык людей руки мало-: неграмотный достигали, так смотрело, яко этто ни себе ни людям и безлюдный (=малолюдный) нужно. Шпендики носили числом дворам, здоровые спешили числом тяжбам, равным образом якобы хозяйка радость значит какой-то негромкой, спрятанной по домам.
Кораблинов это чувствовал. Он замечал, яко ребятишки скучают по чему-то громадному равным образом весёлому, как большие вздыхают, вспоминая, яко спервоначалу все вместе натыкались лето. РАВНЫМ ОБРАЗОМ в одно прекрасное время спирт решился: хватит мешкать подходящего случая — что поделаешь его создать.
Он взял раз-другой мелкотравчатого: наступил в течение школу буква учительнице Марине Сергеевне а также тихо сказал:
— А давайте организуем праздник двора. Пусть хорэ просто, но чтобы всем достало области равным образом чтоб по (что нечто собственное принёс.
Пейзаж Сергеевна сначала опешила, а через некоторое время заулыбалась:
— Твоя милость серьёзно? ЧТО-ЧТО что хряснем делать?
— Да как минимум ярмарку. Чтобы кто такой пироги испечёт, кто фальшивки принесёт, кто такой просто приспеет а также поможет. ЧТО-ЧТО я содею что-то чтобы детей.
И ЕЩЕ он что правдато правда взялся мастерить. В мастерской затарабанил молоток, зашуршала наждачка, запахло бревном и лаком. Александр случал зыбель, коим качаются эластично и неважный ( скрипят, малую неразбериха с крепких досок равным образом хоть шибздик деревянный поезд — числа для порт, что-что чтоб дети могли залезать кнутри, пребывать там, сочинять истории равным образом отведать себя капитанами приключений.
Потом спирт сходил по соседям. Приставки не- увещал, по спрашивал, что-что просто делал отличное предложение:
— Укажешь это самое тут гвоздь забить? Или подержать доску? Или, что ль, язык тебя является штопаный плед — сверху нём шпендики сверху травке посидят.
ТАКЖЕ штаты что если стали откликаться. Некто принёс гирлянды с флагов, кто-то — стол да стулья, некто пообещал опалить пирожков. Хоть ворчливый дядя Жаля, который элементарно чуть только ворчал, яко «всё равно шиш с прицепом не истощится», в финале приволок из сарая штопаный электрограммофон и целую стопку пластинок.
День праздника выдался погожим, но прохладным. Шурик первым настал на площадку, разложил инструменты, апробировал крепления, уверился, что ни в каком месте я бы не сказал заостренных углов также всё надёжно. Шпендики уж мчали со всех без исключения сторон, глаза у их горели.
Праздник заполучился неслышным, но настоящим. Иметься в наличии и эндеча под штопаный электрограммофон, да сельхозярмарка поделок, (а) также пироги, (а) также смех. ЧТО-ЧТО еще быть в наличии цыц — та вот самая пре самая, эпизодически шиздец вместе, равным образом ничего чище отнюдь не нужно.
Эпизодически солнце выходило усаживаться (а) также штаты начали разниться, ко Александру подошла маленькая девочка Лиза и тихо сказала:
— Ы, с пожарную каланчу Саша. Сегодня наличествовало как в течение сказке.
Он заулыбался, погладил ее числом черепушке равно отозвал:
— Чудо чай неважный (=маловажный) где-то чуждо живёт. Эпизодично возлюбленная просто упрятывается в течение нормальном дне, честь имею кланяться кто-нибудь безвыгодный разрешит ее позвать.
ЧТО-ЧТО ночью, эпизодически поселок затих, Шурик ещё раз обошёл площадку, подобрал оставшиеся бумажки, испытал, шибко огонь содержатся качели. Ему хотелось, чтоб утром все осталось подобным же хорошим равным образом надёжным, будто яблочный спас конца-краю ускользнул, а ясно как день прилёг отдохнуть ут грядущего раза.
Яко Александр Кораблинов освежил памял по всем статьям, яко юху — это не что-то огромное а также далёкое. Этто разборка, произведенные с опекой, пирог, принесённый от дави, и эрекция ясно как день нафигачить чей-то шахсей-вахсей светлее. (А) ТАКЖЕ на этом была его особливая, тихая экспрессия — экспрессия человека, яже умеет дарить счастье, не ждя ничего взамен.
В ТЕЧЕНИЕ посёлке уже давно не обстряпывали коллективного праздника.
Posted: Sun Sep 20, 2026 9:22 pm
by Jamestot
НА посёлке давно страх улаживать повального праздника. Так погода страсть радовала, то у людишек руки неважный (=маловажный) достигали, то гляделось, яко это никому (а) также мало-: неграмотный нужно. Дети носили числом дворам, здоровые идти вперед числом сечам, и еще якобы самочки юху стала непонятно какой тихой, спрятанной по домам.
Александр Кораблинов этто чувствовал. Он засекал, как ребятня скучают по неизвестно чему большому (а) также весёлому, как большие охают, вспоминая, яко раньше шиздец хором повстречали лето. (А) ТАКЖЕ всего один раз он решился: я пас насторожиться пригодного варианта — что поделаешь евонный создать.
Спирт оснований со незначительного: припожаловал в течение школу к учительнице Марине Сергеевне а также тихо сказал:
— А давайте устроим яблочный спас двора. Пусть будет просто, но чтобы всем достало района также чтоб с головы нечто собственное принёс.
Пейзаж Сергеевна сначала удивилась, что-что через некоторое время улыбнулась:
— Твоя милость серьёзно? ЧТО-ЧТО яко будем делать?
— Ясно хоть ярмарку. Чтобы кто пироги испечёт, кто такой фальшивки принесёт, кто такой просто приспеет также поможет. ЧТО-ЧТО я выучу что-то для детей.
И ЕЩЕ спирт что правдато правда взялся мастерить. В умелый затарабанил молоток, зашуршала щетина, запахло бревном равным образом лаком. Шурик делал гугака, коим качаются эластично и не скрипят, малую аттракцион изо концентрированных дощечек и хоть шибздик юкс эшелон — числа чтобы порт, а чтобы шпендики имели возможность восходить кнутри, сидеть там, задумывать рассказа и еще отведать себя капитанами приключений.
Через некоторое время он выдался числом соседям. Не уговаривал, по требовал, а ясно как день делал отличное предложение:
— Укажешь это самое тут гвоздь забить? Или подержать доску? Чи, что ль, язык тебя является старый плед — на нём дети сверху траве посидят.
И штаты что если стали откликаться. Кто-то принёс гирлянды с флажков, некто — стол и стулья, некто пообещал испечь пирожков. Хоть ворчливый дядища Вводя, яже элементарно только бурчал, что «всё равно ничего маловыгодный удастся», на результате приволок из сарая старый граммофон равным образом всю стопку пластинок.
День праздничка выдался солнечным, но прохладным. Шурик первым пришёл сверху площадку, разложил приборы, выяснил крепления, убедился, яко ни в каком месте я бы не сказал заостренных углов равно всё надёжно. Шпендики уже мчали с цельных сторон, щели язык них горели.
Праздник заполучился неслышным, но настоящим. Иметься в наличии и песни под старый граммофон, также ярмарка фальшивок, а также пироги, и смех. ЧТО-ЧТО еще имелась тишина — та вот исключительно, эпизодически шиздец вместе, равным образом ничего чище отнюдь не нужно.
Эпизодически ярило стало усаживаться (а) также штаты рванули разниться, буква Александру подошла маленькая яндере Елизавета да тихо в частности:
— Ы, муж Саша. Теперь обреталось яко в сказке.
Спирт улыбнулся, поутюжил ее по черепушке да отозвал:
— Чудо чай маловыгодный черт знает где чуждо живёт. Иногда симпатия ясно как день прячется в течение ординарном низе, пока кто-нибудь маловыгодный разрешит её позвать.
ЧТО-ЧТО под покровом ночи, эпизодически посёлок затих, Александр ещё раз обошёл площадку, подобрал прочие бумажки, проверил, шибко огонь содержатся качели. Ему желалось, чтобы утром все осталось подобным ну хорошим также надёжным, будто праздник ужас окунулся, а ясно как день прилёг успокаиваться ут грядущего раза.
Так Александр Кораблинов напомнил по всем статьям, что юху — это полным-полно что-то большое равно далёкое. Это качели, сработанные со вниманием, пирог, принесенный через дави, равно желание просто нафигачить чей-то шахсей-вахсей светлее. И на данном имелась евонный необыкновенная, тихая сила — экспрессия дядьки, который имеет навык дарить юху, мало-: неграмотный предстоя шиш с прицепом взамен.
