EOS S3 Interrupt Numbers
btashton
gmartin
typedef enum
/******  Cortex-M4 Processor Exceptions Numbers ****************************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                                          */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M4 Memory Management Interrupt                           */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M4 Bus Fault Interrupt                                   */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M4 Usage Fault Interrupt                                 */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M4 SV Call Interrupt                                    */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M4 Debug Monitor Interrupt                              */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M4 Pend SV Interrupt                                    */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M4 System Tick Interrupt                                */
/******  Specific Interrupt Numbers **********************************************************************/
  SwInt2_IRQn                    = 0,
  SwInt1_IRQn                            = 1,
  Reserved1_IRQn                     = 2,
  Ffe0Msg_IRQn                = 3,
  FbMsg_IRQn                        = 4,
  Gpio_IRQn                   = 5,
  SramSleep_IRQn              = 6,
  Uart_IRQn                   = 7,
  Timer_IRQn                  = 8,
  CpuWdtInt_IRQn              = 9,
  CpuWdtRst_IRQn              = 10,
  BusTimeout_IRQn             = 11,
  Fpu_IRQn                    = 12,
  Pkfb_IRQn                   = 13,
  Reserved_I2s_IRQn           = 14,
  Reserved_Audio_IRQn         = 15,
  SpiMs_IRQn                  = 16,
  CfgDma_IRQn                 = 17,
  PmuTimer_IRQn               = 18,
  AdcDone_IRQn                = 19,
  RtcAlarm_IRQn               = 20,
  ResetInt_IRQn               = 21,
  Ffe0_IRQn                   = 22,
  FfeWdt_IRQn                 = 23,
  ApBoot_IRQn                 = 24,
  Ldo30_pg_IRQn               = 25,
  Ldo50_pg_IRQn               = 26,
  Sram_to_IRQn                = 27,
  Lpsd_IRQn        = 28,
  Dmic_IRQn        = 29,
  Reserved2_IRQn                                          = 30,
  Sdma_Done1_IRQn                                     = 31,
  Sdma_Done2_IRQn                                     = 32,
  Sdma_Done3_IRQn                                     = 33,
  Sdma_Done4_IRQn                                     = 34,
  Sdma_Done5_IRQn                                     = 35,
  Sdma_Done6_IRQn                                     = 36,
  Sdma_Done7_IRQn                                     = 37,
  Sdma_Done8_IRQn                                     = 38,
  Sdma_Done9_IRQn                                     = 39,
  Sdma_Done10_IRQn                    = 40,
  Sdma_Done11_IRQn                    = 41,
  Ap_Pdm_Clock_On_IRQn                          = 42,
  Ap_Pdm_Clock_Off_IRQn       = 43,
  Dmac0_Block_Done_IRQn          = 44,
  Dmac0_Buffer_Done_IRQn      = 45,
  Dmac1_Block_Done_IRQn       = 46,
  Dmac1_Buffer_Done_IRQn      = 47,
  Sdma_Done0_IRQn                                     = 48,
  Sdma_Err_IRQn                                 = 49,
  I2SSlv_M4_IRQn                                = 50,
  Lpsd_Voice_Off_IRQn                  = 51,
  Dmic_Voice_Off_IRQn                 = 52
} IRQn_Type;
btashton
gmartin
Looking to get the information you requested. We will be updating our TRM as appropriate, but will reply separately with the information you requested.
gmartin
btashton
Really appreciate it, this is the information I was looking for.
tejar37
Well, I totally agree with you. this is something amazing. I highly admire. Love it. This is something amazing and extra ordinary.
heatherbergh
Be sure you have the right settings and credentials. Never hurst to double check.
roofers in sarasota
oliver28
Hey, if anyone needs a flowchart, we got it here at Electrician Chilliwack.
noahvaughn
Oh, I Am Tired Of Found This Type Of Excellent Article. My Friend Told Me And Send Me This post Link. Well, This Blog Give Some Related Information About tax. I Really Inspired Your Posting. Keep It Up And Update This Type Of Marvelous Information. super funds tax returns.
