EOS S3 Camera Power Optimization
lylybrown
Contact:
Hi everyone, I’m working on a low-power camera application using the EOS S3, and I’m trying to optimize power consumption during intermittent image capture (e.g., capturing 1 frame every few seconds). Currently, I see higher-than-expected power draw even when the system is mostly idle between captures.
Has anyone here successfully minimized power usage in a similar use case? Specifically:
Which sleep mode works best between captures?
Are there recommended ways to fully gate the camera interface or MIPI block when not in use?
Any tips for reducing wake-up latency without increasing overall power consumption?
Appreciate any insights or examples from real projects!
nancy266
great post
costgross
What sleep mode are you currently using between captures?
gordonpiper
I ran into the same issue on EOS S3, and the key insight for me was that “idle” isn’t really low power unless you explicitly shut things down.
Dublinra
This is a great question! Optimizing power for intermittent capture on the EOS S3 can be tricky. For sleep modes, have you looked into deep sleep with an RTC wake-up?
Snow Rider 3D
olivianaylor12
good idea
ramikaseo
Independent Escort Service in Delhi offers refined seduction without compromise. She looks expensive, feels expensive, and knows how to leave you completely spent and smiling. Soft caresses, lingering kisses, and a body made for pleasure. Quiet luxury with intense desire for those who want only the finest.
