Simple streaming QFB data to SensiML DCL
timothym
I am using example binary file quickfeather-simple-stream-data-collection.bin from following link:
https://sensiml.com/documentation/firmw ... ather.html
I want to know that does this example firmware require USB to TTL serial adapter?
is following adapter compitable?
https://robu.in/product/ft232rl-usb-to- ... r-arduino/
FT232 has following pins
FTDI ------ QFB
GND —-> GND
VCC —-> VCC
TX —–> Pin 2
RX —-> Pin 3
DTR —-> ?
where should I connect DTR?
ale@quicklogic.com
QuickFeather UART supports RX and TX only. There is no support for Control signals.
chrisharrison3456
The example firmware "quickfeather-simple-stream-data-collection.bin" does not require a USB to TTL serial adapter for basic functionality. However, if you want to debug or monitor the firmware's output, you will need a USB to TTL serial adapter.
The FT232RL USB to TTL serial adapter you mentioned should be compatible with the QuickFeather board. To connect it to the QuickFeather board, you can connect the pins as follows:
Connect the GND pin of the adapter to the GND pin of the QuickFeather board.
Connect the VCC pin of the adapter to the VCC pin of the QuickFeather board.
Connect the TX pin of the adapter to pin 2 (RX) of the QuickFeather board.
Connect the RX pin of the adapter to pin 3 (TX) of the QuickFeather board.
Connect the DTR pin of the adapter to the RESET pin of the QuickFeather board.
By connecting the DTR pin to the RESET pin, the adapter can reset the QuickFeather board when needed, which is useful for programming the board.
anamint minths
If you are talking about qf_hardwaresetup.c normally it is in qorc-sdk\BSP\quickfeather\src\.
But some project might have it own, for example, like qorc-sdk\qf_apps\qf_ssi_ai_app\src\qf_hardwaresetupgeometry dash subzeroc
silaselena2
If you are referring to **qf_hardwaresetup.c**, it is usually located in `qorc-sdk\BSP\quickfeather\src\`. However, some projects may include their own version of this file. For example, it can also be found in `qorc-sdk\qf_apps\qf_ssi_ai_app\src\qf_hardwaresetup.c`.
cafe
You don’t really need the adapter unless you want to see data on the screen or debug RX/TX is enough for that anyway. DTR isn’t supported on the board, so wiring it to reset might work in some setups but isn’t actually part of the intended design.broken screen
