EOS S3 Interrupt Numbers
btashton
Post by btashton »
gmartin
Re: EOS S3 Interrupt Numbers
Post by gmartin »
typedef enum
/******  Cortex-M4 Processor Exceptions Numbers ****************************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                                          */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M4 Memory Management Interrupt                           */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M4 Bus Fault Interrupt                                   */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M4 Usage Fault Interrupt                                 */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M4 SV Call Interrupt                                    */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M4 Debug Monitor Interrupt                              */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M4 Pend SV Interrupt                                    */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M4 System Tick Interrupt                                */
/******  Specific Interrupt Numbers **********************************************************************/
  SwInt2_IRQn                    = 0,
  SwInt1_IRQn                            = 1,
  Reserved1_IRQn                     = 2,
  Ffe0Msg_IRQn                = 3,
  FbMsg_IRQn                        = 4,
  Gpio_IRQn                   = 5,
  SramSleep_IRQn              = 6,
  Uart_IRQn                   = 7,
  Timer_IRQn                  = 8,
  CpuWdtInt_IRQn              = 9,
  CpuWdtRst_IRQn              = 10,
  BusTimeout_IRQn             = 11,
  Fpu_IRQn                    = 12,
  Pkfb_IRQn                   = 13,
  Reserved_I2s_IRQn           = 14,
  Reserved_Audio_IRQn         = 15,
  SpiMs_IRQn                  = 16,
  CfgDma_IRQn                 = 17,
  PmuTimer_IRQn               = 18,
  AdcDone_IRQn                = 19,
  RtcAlarm_IRQn               = 20,
  ResetInt_IRQn               = 21,
  Ffe0_IRQn                   = 22,
  FfeWdt_IRQn                 = 23,
  ApBoot_IRQn                 = 24,
  Ldo30_pg_IRQn               = 25,
  Ldo50_pg_IRQn               = 26,
  Sram_to_IRQn                = 27,
  Lpsd_IRQn        = 28,
  Dmic_IRQn        = 29,
  Reserved2_IRQn                                          = 30,
  Sdma_Done1_IRQn                                     = 31,
  Sdma_Done2_IRQn                                     = 32,
  Sdma_Done3_IRQn                                     = 33,
  Sdma_Done4_IRQn                                     = 34,
  Sdma_Done5_IRQn                                     = 35,
  Sdma_Done6_IRQn                                     = 36,
  Sdma_Done7_IRQn                                     = 37,
  Sdma_Done8_IRQn                                     = 38,
  Sdma_Done9_IRQn                                     = 39,
  Sdma_Done10_IRQn                    = 40,
  Sdma_Done11_IRQn                    = 41,
  Ap_Pdm_Clock_On_IRQn                          = 42,
  Ap_Pdm_Clock_Off_IRQn       = 43,
  Dmac0_Block_Done_IRQn          = 44,
  Dmac0_Buffer_Done_IRQn      = 45,
  Dmac1_Block_Done_IRQn       = 46,
  Dmac1_Buffer_Done_IRQn      = 47,
  Sdma_Done0_IRQn                                     = 48,
  Sdma_Err_IRQn                                 = 49,
  I2SSlv_M4_IRQn                                = 50,
  Lpsd_Voice_Off_IRQn                  = 51,
  Dmic_Voice_Off_IRQn                 = 52
} IRQn_Type;
btashton
Post by btashton »
gmartin
Post by gmartin »
Looking to get the information you requested. We will be updating our TRM as appropriate, but will reply separately with the information you requested.
gmartin
Post by gmartin »
btashton
Post by btashton »
Really appreciate it, this is the information I was looking for.
