EOS S3 Interrupt Numbers
btashton
gmartin
typedef enum
/******  Cortex-M4 Processor Exceptions Numbers ****************************************************************/
  NonMaskableInt_IRQn         = -14,    /*!< 2 Non Maskable Interrupt                                          */
  MemoryManagement_IRQn       = -12,    /*!< 4 Cortex-M4 Memory Management Interrupt                           */
  BusFault_IRQn               = -11,    /*!< 5 Cortex-M4 Bus Fault Interrupt                                   */
  UsageFault_IRQn             = -10,    /*!< 6 Cortex-M4 Usage Fault Interrupt                                 */
  SVCall_IRQn                 = -5,     /*!< 11 Cortex-M4 SV Call Interrupt                                    */
  DebugMonitor_IRQn           = -4,     /*!< 12 Cortex-M4 Debug Monitor Interrupt                              */
  PendSV_IRQn                 = -2,     /*!< 14 Cortex-M4 Pend SV Interrupt                                    */
  SysTick_IRQn                = -1,     /*!< 15 Cortex-M4 System Tick Interrupt                                */
/******  Specific Interrupt Numbers **********************************************************************/
  SwInt2_IRQn                    = 0,
  SwInt1_IRQn                            = 1,
  Reserved1_IRQn                     = 2,
  Ffe0Msg_IRQn                = 3,
  FbMsg_IRQn                        = 4,
  Gpio_IRQn                   = 5,
  SramSleep_IRQn              = 6,
  Uart_IRQn                   = 7,
  Timer_IRQn                  = 8,
  CpuWdtInt_IRQn              = 9,
  CpuWdtRst_IRQn              = 10,
  BusTimeout_IRQn             = 11,
  Fpu_IRQn                    = 12,
  Pkfb_IRQn                   = 13,
  Reserved_I2s_IRQn           = 14,
  Reserved_Audio_IRQn         = 15,
  SpiMs_IRQn                  = 16,
  CfgDma_IRQn                 = 17,
  PmuTimer_IRQn               = 18,
  AdcDone_IRQn                = 19,
  RtcAlarm_IRQn               = 20,
  ResetInt_IRQn               = 21,
  Ffe0_IRQn                   = 22,
  FfeWdt_IRQn                 = 23,
  ApBoot_IRQn                 = 24,
  Ldo30_pg_IRQn               = 25,
  Ldo50_pg_IRQn               = 26,
  Sram_to_IRQn                = 27,
  Lpsd_IRQn        = 28,
  Dmic_IRQn        = 29,
  Reserved2_IRQn                                          = 30,
  Sdma_Done1_IRQn                                     = 31,
  Sdma_Done2_IRQn                                     = 32,
  Sdma_Done3_IRQn                                     = 33,
  Sdma_Done4_IRQn                                     = 34,
  Sdma_Done5_IRQn                                     = 35,
  Sdma_Done6_IRQn                                     = 36,
  Sdma_Done7_IRQn                                     = 37,
  Sdma_Done8_IRQn                                     = 38,
  Sdma_Done9_IRQn                                     = 39,
  Sdma_Done10_IRQn                    = 40,
  Sdma_Done11_IRQn                    = 41,
  Ap_Pdm_Clock_On_IRQn                          = 42,
  Ap_Pdm_Clock_Off_IRQn       = 43,
  Dmac0_Block_Done_IRQn          = 44,
  Dmac0_Buffer_Done_IRQn      = 45,
  Dmac1_Block_Done_IRQn       = 46,
  Dmac1_Buffer_Done_IRQn      = 47,
  Sdma_Done0_IRQn                                     = 48,
  Sdma_Err_IRQn                                 = 49,
  I2SSlv_M4_IRQn                                = 50,
  Lpsd_Voice_Off_IRQn                  = 51,
  Dmic_Voice_Off_IRQn                 = 52
} IRQn_Type;
btashton
gmartin
Looking to get the information you requested. We will be updating our TRM as appropriate, but will reply separately with the information you requested.
gmartin
btashton
Really appreciate it, this is the information I was looking for.
tejar37
Well, I totally agree with you. this is something amazing. I highly admire. Love it. This is something amazing and extra ordinary.
Tratc1956
Thanks @gmartin for the answers. I am looking forward to more answers about this one as I have the same problem.
atlanta mobile detailing
tejar37
This guide provides users with functional descriptions, configuration options for the QuickLogic Thing Plus EOS S3. It also serves as a “Getting Started".
Bradley Fields
I just joined the community looking for help and found someone with the same problem and the answer! Awesome. Your answer helped me a lot getaway shootout
