I'm currently working on a project involving QuickLogic chips, and I'm running into some configuration issues. Has anyone here had experience setting up and programming these chips? Any tips, resources, or insights you can share would be incredibly helpful!
Thanks in advance!
Seeking Help with QuickLogic Chip Configuration
I can only give you some advice. When working, you should clearly understand a few things as follows:
1. Development Tools:
Application Notes: Look for application notes on the QuickLogic website, as they can provide insights into common use cases and configurations.
3. Programming and Configuration HDL (VHDL/Verilog): If you are programming the chip using HDL, ensure your syntax and structure align with the chip's requirements. QuickLogic supports various HDL inputs, so check compatibility.
FPGA Programming: If you're using a QuickLogic FPGA, familiarize yourself with the synthesis and place-and-route tools provided in the development kit.
Hope it is useful to you!
- QuickLogic Development Kit: Make sure you have the appropriate development kit for your chip. This often includes example projects and libraries.
QuickLogic IDE: Use the QuickLogic software tools, such as the QuickLogic development environment, which includes device configuration, design entry, and simulation capabilities.
Use the QuickLogic QuickFeather or other supported development boards to simplify initial setup. Install the necessary tools, such as the QuickLogic Toolchain and IDE (usually Eclipse-based). You should pay close attention to the pin mappings. The datasheets provide detailed pin configurations, so ensure your connections match.horrifiedfur wrote: ↑Wed Jul 03, 2024 1:31 am Hi everyone,
Thanks in advance!
