Error while compiling qorc sdk sample code in eclipse
timothym
I have downloaded all requirements and configured the eclipse as instructed in https://github.com/QuickLogic-Corp/qorc ... Readme.txt
but while building the project I am getting the following error
my build settings are following
can anyone please help urgently.....thanks
phil_quik
I think the way to create virtual project did matter.
Below is my working setup
timothym
Hi phil_quik thanks but can you please help me with steps because I don't know how to create virtual project. thanks.
phil_quik
I think it is mentioned in item 4 as copied below.
4. Add files and folder to the Eclipse Virtual filesystem
Drag and drop the folder QL-EOSS3-SW/BSP to the newly created project
On the "File and Folder Operation" dialog box, choose
- Link to files and recreate folder structure with virtual folders and
- Check the Create link locations relative to PROJECT_LOC
Similarly drag and drop other folders:
FReeRTOSv8_2_2, HAL, Libraries, and Tasks
Create Virtual Folder named "App".
On the Eclipse IDE, select <YourProject>, Click on File -> New -> Folder
On the "New Folder" dialog box, specify the folder name as "App",
click the "Advanced" tab and select the radio button "Folder is not
located in the file system (Virtual Folder)" and click Finish
Create Virtual folder named "YourProject"
Drag and drop from your "App/YourProject" the following folders:
GCC_Project/, src/, and inc/ folders to the newly created
"App/YourProject" virtual folder.
timothym
Where is BSP? is there any video tutorial?
phil_quik
Most folders are under qorc-sdk\
BSP\
HAL\
Libraries\
Tasks\
timothym
Thanks a lot!!!
User avatar
Sjackson3289
I appreciate everything you have added here in this post. ThnksForTheHelp (TFTH) is an excellent academic help platform that provides homework and assignment assistance so during exam times and normal days students don't need to stress about doing the assignments as they will be done by the top experts.
