Helloworld error
Posted: Sun Jun 21, 2020 10:02 am
				While installing zephyr SDK using the command
./zephyr-sdk-0.11.2-setup.run -- -d ~/zephyr-sdk-0.11.2
I get below error many times while it instal arm packages
[|] Installing arm64 tools...sleep: cannot read realtime clock: Invalid argument
But finally it says the installation is through.
Later, after completing all remaining the steps of setup, when I tried compiling HelloWorld sample, it gives error:
Assertion failed: The detected dtc version is unsupported.
The version was found to be 0
But the minimum supported version is 1.4.6
See https://docs.zephyrproject.org/latest/getting_started/
for how to use the SDK's dtc alongside a custom toolchain.
