hello world build error
Posted: Wed Jun 03, 2020 2:12 am
OS: ubuntu 20.04 64bit running on VMWare workstation 15 player
I followed the doc,Working.with.Zephyr.pdf, to build but failed.
Below is the error log.
phil@ubuntu:~/zephyrproject/zephyr/samples/hello_world$ west build -b quick_feather
-- west build: build configuration:
source directory: /home/phil/zephyrproject/zephyr/samples/hello_world
build directory: /home/phil/zephyrproject/zephyr/samples/hello_world/build (created)
BOARD: quick_feather (origin: command line)
-- west build: generating a build system
Zephyr version: 2.1.99
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.2", minimum required is "3.6")
-- Selected BOARD quick_feather
-- Found west: /home/phil/.local/bin/west (found suitable version "0.7.2", minimum required is "0.6.0")
-- Loading /home/phil/zephyrproject/zephyr/boards/arm/quick_feather/quick_feather.dts as base
quick_feather.dts.pre.tmp:65.14-73.5: Warning (simple_bus_reg): /soc/gpio: missing or empty reg/ranges property
Devicetree configuration written to /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/include/generated/generated_dts_board.conf
Parsing Kconfig tree in /home/phil/zephyrproject/zephyr/Kconfig
Loaded configuration '/home/phil/zephyrproject/zephyr/boards/arm/quick_feather/quick_feather_defconfig'
Merged configuration '/home/phil/zephyrproject/zephyr/samples/hello_world/prj.conf'
Configuration saved to '/home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/.config'
-- The C compiler identification is GNU 9.2.0
-- The CXX compiler identification is GNU 9.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /home/phil/zephyr-sdk-0.11.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Cache files will be written to: /home/phil/.cache/zephyr
-- Configuring done
-- Generating done
-- Build files have been written to: /home/phil/zephyrproject/zephyr/samples/hello_world/build
-- west build: building application
[1/112] Preparing syscall dependency handling
[2/112] Generating include/generated/driver-validation.h
FAILED: zephyr/include/generated/driver-validation.h
cd /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr && /usr/bin/python3 /home/phil/zephyrproject/zephyr/scripts/gen_kobject_list.py --validation-output /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/include/generated/driver-validation.h
File "/home/phil/zephyrproject/zephyr/scripts/gen_kobject_list.py", line 59, in <module>
from elf_helper import ElfHelper, kobject_to_enum
File "/home/phil/zephyrproject/zephyr/scripts/elf_helper.py", line 14, in <module>
import elftools
ModuleNotFoundError: No module named 'elftools'
[3/112] Generating include/generated/k...um.h, include/generated/otype-to-str.h
FAILED: zephyr/include/generated/kobj-types-enum.h zephyr/include/generated/otype-to-str.h
cd /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr && /usr/bin/python3 /home/phil/zephyrproject/zephyr/scripts/gen_kobject_list.py --kobj-types-output /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/include/generated/kobj-types-enum.h --kobj-otype-output /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/include/generated/otype-to-str.h --kobj-size-output /home/phil/zephyrproject/zephyr/samples/hello_world/build/zephyr/include/generated/otype-to-size.h
import elftools
ninja: build stopped: subcommand failed.
FATAL ERROR: command exited with status 1: /usr/bin/cmake --build /home/phil/zephyrproject/zephyr/samples/hello_world/build
-- Configuring done
-- Generating done
import elftools
import elftools
