Hi Team,
Let me clarify on the installation process on the Red Hat Enterprise Linux Server release 7.7.
Here is my installation setting followed the "Symbiflow Installation Guide and Tutorial."
1. >chmod 755 ./Symbiflow-Linux-7-3_05_15_2020.gz.run
2. >export SYM_INSTALL_PATH=/home/username/Tool/
3. >./Symbiflow-Linux-7-3_05_15_2020.gz.run
4. >cd /home/username/Tool/symbiflow-arch-defs/install/bin
5. >source ql_env
6. >cd /home/username/Work
7. >ql_symbiflow -h
[username@machinename Work]$ ql_symbiflow -h
Below are the supported commands:
To synthesize and dump a eblif file:
>ql_symbiflow -synth -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
To run synthesis, pack, place and route, generate bitstream:
>ql_symbiflow -compile -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
To generate the jlink file:
>ql_symbiflow -jlink -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
To generate the post verilog file:
>ql_symbiflow -post_verilog -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file >
To generate the ascii header file from bitstream:
>ql_symbiflow -bit2header -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
To generate the ascii header file from jlink:
>ql_symbiflow -jlink2header -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file >
Device supported:ql-eos-s3
Packages supported PD64,PU64,WR42
-h
/home/username/Tool/symbiflow-arch-defs/install/bin/ql_symbiflow: line 224: /v_list: Permission denied
Is this correct? or need any correction on installation?
thanks for your advise!!
Installation on the Red Hat Enterprise Linux Server release 7.7
I have the same issue with a Windows 10 machine running VM and CentOS 7.x
[seb2001@localhost ~]$ chmod 755 Symbiflow_Linux-7-3_05_15_2020.gz.run
[seb2001@localhost ~]$ SYM_INSTALL_PATH=$HOME
[seb2001@localhost ~]$ ./Symbiflow_Linux-7-3_05_15_2020.gz.run
bash: ./Symbiflow_Linux-7-3_05_15_2020.gz.run: /bin/sh: bad interpreter: Text file busy
[seb2001@localhost ~]$ ls
Desktop Downloads Pictures Symbiflow_Linux-7-3_05_15_2020.gz.run Videos
Documents Music Public Templates
Verifying archive integrity... 100% All good.
Uncompressing Symbiflow Installer 100%
Installation starting for symbiflow
OS Requirement: Linux release 7.3 (Final) and above.
Copyright: QuickLogic Corporation
$SYM_INSTALL_PATH is not set!
Do you want to install it to the default location /home/seb2001 ? <Y/N> n
To install to another custom location, please export the custom path to $SYM_INSTALL_PATH and execute the installer again in the same terminal.
Example: "export SYM_INSTALL_PATH=/sample_location/sample_folder".
Do you want to install it to the default location /home/seb2001 ? <Y/N> y
Setting $SYM_INSTALL_PATH to /home/seb2001 .
Installation is complete.
[seb2001@localhost ~]$ cd symbiflow-arch-defs/install/bin
[seb2001@localhost bin]$ source ql_env
[seb2001@localhost bin]$ ql_symbiflow -h
>ql_symbiflow -post_verilog -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
>ql_symbiflow -jlink2header -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
-h
/home/seb2001/symbiflow-arch-defs/install/bin/ql_symbiflow: line 224: /v_list: Permission denied
-h
Please use the latest build dated 21st May. Also commands have changed, so refer the tutorial document.
https://teams.microsoft.com/_#/files/FO ... _Installer
