Page 1 of 2
Symbiflow installation problem
Posted: Mon Feb 12, 2024 10:24 pm
by lessaro
First, I'm not a Linux (Ubuntu) expert!
I need help installing Symbiflow with Ubuntu (under Window 10 WSL).
I have made many attempt with: laptop running Ubuntu, Ubuntu on Windows with VM and they all failled!
The installation seem to go fine but when I try to run the counter example it fail.
The directory structure of Symbiflow seem to be wrong!
I have followed the "Installing Symbiflow on Linux" guide and tutorial from the document QuickLogic-FPGA-Toolchain Release 1.0.0. The installer file is Symbiflow_v1.3.2.gz.run.
I have join some log files of the installation and the compilation of the exemple.
Re: Symbiflow installation problem
Posted: Wed Dec 11, 2024 3:37 am
by Benjaminn
I have the same problem as you
Posted: Tue May 06, 2025 2:14 am
by sarausa
Regarding the directory structure that you suspect is wrong, can you describe it more specifically? What did you expect the directory structure to be like and how is it different from what you see?
Posted: Thu Jun 26, 2025 2:06 am
by tommchris
Based on your previous questions about the Velocity Raptor game from TestTubeGames and the Simutrans forum, it seems you might be referring to a technical issue related to installing software, possibly on a Linux system, given the context of forums and open-source tools. Sprunki
Posted: Wed Aug 13, 2025 9:19 am
by holeioonline
lessaro wrote: Mon Feb 12, 2024 10:24 pm Hi,
Sometimes a small mistake during installation can cause a lot of problems. You can try to completely uninstall Symbiflow and reinstall it following the official instructions.
Posted: Thu Dec 25, 2025 10:24 am
by JolieKeva
It appears you could be talking about a technical problem connected to software installation, likely on a Linux system, based on the context of forums and open-source tools deer adventure
Posted: Thu Jan 29, 2026 10:06 am
by geometrylitegame
I have made many attempt with: laptop running Ubuntu, Geometry Dash Ubuntu on Windows with VM and they all failled!
SymbiFlow + QuickLogic tools are not officially supported on WSL, and they are unreliable inside VMs.
Posted: Thu Feb 12, 2026 3:55 am
by bevisjame
stickman hook
It seems you're facing challenges with Symbiflow installation on Ubuntu under WSL. Here are a few quick tips:
Check Dependencies: Ensure all required packages are installed.
Run as Admin: Use sudo to execute the installer.
Verify Directory Structure: Make sure the files are correctly extracted.
Review Logs: Look for specific error messages in the logs.
Use WSL 2: Ensure you're on WSL 2 for better compatibility.
Sharing specific error messages can help in diagnosing the issue further!
Posted: Sat Feb 14, 2026 8:15 am
by amongusfree
Since you're using Windows 10 + WSL (Ubuntu), there are a few common failure points that can cause the counter example to fail even if installation appears successful.
Among Us
Posted: Fri Mar 06, 2026 1:28 am
by Bradley Fields
Because you're using Windows 10 with WSL (Ubuntu), even if installation seems to be successful, there are a few frequent failure locations that can cause the hollow knight counter example to fail.
