RR graph and arch warning when running VPR
Posted: Thu Jun 04, 2020 4:08 am
by brianfaith
When I P&R, I get the following warnings:
Warning 109: This RR graph file is based on /home/bfaith/symbiflow/symbiflow-arch-defs/install/share/arch/ql-eos-s3_wlcsp/arch.timing.xml while your input architecture file is Generated from arch file /home/kkumar/symbiflow-arch-defs/build/quicklogic/devices/ql-eos-s3-virt/arch.timing.xml compatability issues may arise
Warning 110: This architecture version is for VPR 8.1.0-dev+8980e4621 while your current VPR version is 8.1.0-dev+unkown compatability issues may arise
Re: RR graph and arch warning when running VPR
Posted: Thu Jun 04, 2020 3:49 pm
by kkumar
Antmicro provided the fix for 109.
Warning 109 is now removed but Warning 110 still exists, will be removed during the conda based build.
Posted: Mon Jun 08, 2020 4:07 am
by brianfaith
What downloadable version has the 109 fix?
Posted: Mon Jun 08, 2020 7:51 am
by kkumar
The fix is only on the tar package. As the fix was provided a day before release.
Lalit has integrated the pull request now to the github.
https://github.com/QuickLogic-Corp/symb ... h-defs.git -b quicklogic-upstream-rebase
