Software is not my, um, strong point. I am following directions to set up Symbiflow as described here https://symbiflow.readthedocs.io/en/lat ... repository. I cloned the GitHub repository, unzipped the file to the new directory. The screenshot is attached. My problem is the next step which is, in terminal, type "make env". This is the result:
otto@juice:~/Documents/symbiflow-arch-defs$ make env
git submodule init
make: git: Command not found
Makefile:10: third_party/make-env/conda.mk: No such file or directory
make: *** [Makefile:7: third_party/make-env/conda.mk] Error 127
Time to ask an expert, or at least, someone who has been here.
My system is Linux Mint 20.
Trying to set up Symbiflow
otto9Q9otto
- Attachments
- symbiflow.png (170.51 KiB) Viewed 146496 times
Hi!
The error you are seeing is because it doesn't seem like git is installed on your system, see the error message;
Assuming you just want to use an existing QuickFeather board, you should probably look at one of the following repositories;
Tim 'mithro' Ansell
On a side note, the instructions you are following are for getting set up as a SymbiFlow Developer, (IE you want to help do development on the toolchain) rather than a SymbiFlow user (I just want to use an existing FPGA that I have).make: git: Command not found
- The SymbiFlow examples repository at https://github.com/SymbiFlow/symbiflow-examples
- The QuickLogic FPGA toolchain at https://github.com/QuickLogic-Corp/quic ... -toolchain
- The "Getting Started" repository at https://github.com/QuickLogic-Corp/Getting_started
Tim 'mithro' Ansell
otto9Q9otto
Following directions https://github.com/QuickLogic-Corp/quic ... -toolchain, in terminal I entered
More than a dozen software packages was then installed, including python. It sort of looks like I am being set up as a developer, but that's OK.
Then I tried the first example:
What do I do now?
otto@juice:~/Documents/verilog/symbiflow$ export INSTALL_DIR=~/Documents/verilog/symbiflowThen I tried the first example:
otto@juice:~/Documents/verilog/symbiflow/install/tests/counter_16bit$ ql_symbiflow -compile -d ql-eos-s3 -P pd64 -v counter_16bit.v -t top -p chandalar.pcf
bash: ql_symbiflow: command not foundHi otto9Q9otto,
Yes there are many dependent packages that gets installed. once you finish with installation , to run the example follow these steps:
#To Run example
export INSTALL_DIR="specify the installpath"
export PATH="$INSTALL_DIR/install/bin:$INSTALL_DIR/install/bin/python:$PATH"
source "$INSTALL_DIR/conda/etc/profile.d/conda.sh"
conda activate
and then:
#To Run example
conda activate
and then:
otto9Q9otto
Hi kkumar,
Your suggestion worked up to the point indicated:
What should I do now?
otto@juice:~/Documents/verilog/symbiflow/install$ export INSTALL_DIR=~/Documents/verilog/symbiflow/install/tests/counter_16bit
otto@juice:~/Documents/verilog/symbiflow/install$ export PATH="$INSTALL_DIR/install/bin:$INSTALL_DIR/install/bin/python:$PATH"
otto@juice:~/Documents/verilog/symbiflow/install$ source "$INSTALL_DIR/conda/etc/profile.d/conda.sh"
bash: /home/otto/Documents/verilog/symbiflow/install/tests/counter_16bit/conda/etc/profile.d/conda.sh: No such file or directory
The steps are right, but the export INSTALL_DIR, which you have mentioned is for example directory. It should point to the location where the installation was carried out. It would have the folders conda and install. In your case it is : INSTALL_DIR=~/Documents/verilog/symbiflow
otto9Q9otto
Thanks, kkumar for the hand-holding. For the benefit of others who may be similarly clueless, here is what worked (on Linux Mint 20):
At https://github.com/QuickLogic-Corp/quic ... -toolchain: There is the direction:
I chose the /home/otto/Documents/verilog/symbiflow for the installation, so my version is:
More than a dozen packages were installed, but kkumar said not to worry.
Now to run an example:
In terminal, change directory to ~/Documents/verilog/symbiflow, then:
Which then did a lot of stuff, and ended with:
Success!
bash Symbiflow_v1.3.0.gz.runCode: Select all
bash Symbiflow_v1.3.0.gz.runNow to run an example:
otto@juice:~/Documents/verilog/symbiflow$ export PATH="$INSTALL_DIR/install/bin:$INSTALL_DIR/install/bin/python:$PATH"
otto@juice:~/Documents/verilog/symbiflow$ source "$INSTALL_DIR/conda/etc/profile.d/conda.sh"
otto@juice:~/Documents/verilog/symbiflow$ conda activate
otto@juice:~/Documents/verilog/symbiflow$ ql_symbiflow -compile -d ql-eos-s3 -P pd64 -v counter_16bit.v -t top -p chandalar.pcfCode: Select all
Writing bitstream ...The error make: git: Command not found just means git isn’t installed—install it first (sudo apt install git).otto9Q9otto wrote: ↑Fri Oct 16, 2020 12:13 am Software is not my, um, strong point. I am following directions to set up Symbiflow as described here https://symbiflow.readthedocs.io/en/lat ... repository. I cloned the GitHub repository, unzipped the file to the new directory. The screenshot is attached. My problem is the next step which is, in terminal, type "make env". This is the result:
git submodule init
My system is Linux Mint 20. poki
Also, the guide you’re following is for toolchain developers, not regular users. If you just want to use the FPGA, switch to the QuickLogic “Getting Started” or toolchain repo instead.
Finally, the ql_symbiflow: command not found error usually means your environment isn’t set—make sure you’ve activated the conda environment and updated your PATH.
