First, I'm not a Linux (Ubuntu) expert!
I need help installing Symbiflow with Ubuntu (under Window 10 WSL).
I have made many attempt with: laptop running Ubuntu, Ubuntu on Windows with VM and they all failled!
The installation seem to go fine but when I try to run the counter example it fail.
The directory structure of Symbiflow seem to be wrong!
I have followed the "Installing Symbiflow on Linux" guide and tutorial from the document QuickLogic-FPGA-Toolchain Release 1.0.0. The installer file is Symbiflow_v1.3.2.gz.run.
I have join some log files of the installation and the compilation of the exemple.
Symbiflow installation problem
- Attachments
- symbiflow-dir-tree.zip
- (27.01 KiB) Downloaded 3017 times
- Symbiflow-install.zip
- (9.86 KiB) Downloaded 2908 times
Regarding the directory structure that you suspect is wrong, can you describe it more specifically? What did you expect the directory structure to be like and how is it different from what you see?
Based on your previous questions about the Velocity Raptor game from TestTubeGames and the Simutrans forum, it seems you might be referring to a technical issue related to installing software, possibly on a Linux system, given the context of forums and open-source tools. Sprunki
Sometimes a small mistake during installation can cause a lot of problems. You can try to completely uninstall Symbiflow and reinstall it following the official instructions.lessaro wrote: ↑Mon Feb 12, 2024 10:24 pm Hi,
