When trying to run ql_symbiflow -h, there is a Permission denied error
[plin@mahanadi bin]$ ql_symbiflow -h
Below are the supported commands:
 To synthesize and dump a eblif file:
        >ql_symbiflow -synth -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
 To run synthesis, pack, place and route, generate bitstream:
        >ql_symbiflow -compile -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
 To generate the jlink file:
        >ql_symbiflow -jlink -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
 To generate the post verilog file:
        >ql_symbiflow -post_verilog -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
 To generate the ascii header file from bitstream:
        >ql_symbiflow -bit2header -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
 To generate the ascii header file from jlink:
        >ql_symbiflow -jlink2header -src <source_dir path> -d <device> -k <package> -t <top> -v <verilog_list file> -p <pcf file>
Device supported:ql-eos-s3
Packages supported PD64,PU64,WR42
-h
/home/plin/Symbiflow/symbiflow-arch-defs/install/bin/ql_symbiflow: line 224: /v_list: Permission denied
